Avid Fairchild 670 Pro Tools 10 and 11 issue
I have a single license for the Avid Fairchild 670 and the plugin is not showing up in PT 10 or PT 11. Any ideas on how to get the 670 working in at least PT 10 or PT 11 and which installer I should use for a Mac Pro ? I was under the impression the 670 single license should at least work in PT 10 and maybe PT 11. My BF3A single license is working in PT 10 and PT 11.
Re: Avid Fairchild 670 Pro Tools 10 and 11 issue
Separate and updated installers for the Fairchild bundle.
Check the Plug-ins page.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
If memory serves, the 670 is a STEREO plugin, and the 660 is the MONO version. So if you try to put a 670 on a mono track, it indeed won't show up. At least I think so...
It wouldn't hurt to trash your prefs either. That way the system has to scan all the plugins in the plugin folder again
Thanks for the reply's. I have trashed prefs etc..
Should I be using the classic compressors installer or the Fairchild bundle installer for PT 10 ? |
I don't remember / but i do remember using 2 different installers for PT10 and another for PT11
Yes. Then put the plugins that you do not a license for in the unused plugin folder.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
Except I doubt if the PT 10 installer has a 64-bit AAX Fairchild installer, which you need for PT 11. Which could explain why it doesn't show up in PT 11. Go to this page: http://www.avid.com/US/products/Clas...ressors-Bundle I believe you'll have to do a 32-bit AAX install for PT 10 (if you're still using it) and a separate 64-bit AAX install for PT 11. Last edited by sw rec; 04-14-2014 at 09:08 AM. |
F/S: Avid Fairchild Bundle,Smack!,Impact | Glenjb | Buy & Sell | 14 | 06-16-2014 10:50 AM |
Issue with Avid: Pro Tools 10 and Retina Display/Mavericks | jakemiller | macOS | 0 | 02-01-2014 12:32 PM |
Hardware Issue?? Avid Help! | dhmusic | Pro Tools TDM Systems (Mac) | 0 | 12-30-2012 04:11 PM |
BF Classic Compressors v4 License don't authorize Fairchild in Pro Tools 8. | eastwind | Pro Tools TDM Systems (Mac) | 3 | 08-22-2010 11:29 AM |
