  #21
Old 04-18-2021, 07:37 PM
SomeOtherGuy SomeOtherGuy is offline
Default Re: Okay, so I like Dark Mode but...
I don’t know the answer to that. I haven’t fooled with any dark mode mods either, and my monitor is calibrated.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
  #22
Old 04-19-2021, 03:38 AM
It's not just the colors but the header is completely different than mine. I know one can hide certain elements but not almost everything like in yours. Near as I can figure there's no way to hide the smart tools. I even installed a clean no-messed with 2021.3.1 and the MIDI editor looks nothing like yours in the header.
Like I offered earlier I can send you the dark mode file I'm using; you'll have to manually change the line I mentioned earlier in this thread because I haven't worked out a good color so different track colors work with it. This is one of those things where color is personal to each person and what they see best; has nothing to do with monitor calibration.
Jack
QAPLA!
  #23
Old 04-19-2021, 04:24 AM
innesireinar innesireinar is offline
Originally Posted by musicman691 View Post
Can't say that I've seen the difference you're talking about and I use all manner of different colors so I should have seen it.
I set each track color individually so I can display multiple tracks in the MIDI editor with each track a different color. Where I have an issue is if I have multiple tracks of the same color. For instance I tend to color string tracks greenish, brass tracks reddish, etc. But I only do that after I have all my MIDI notes entered.
As far as some colors not reading well that depends on several factors: brightness & contrast of the screen, room light and color sensitivity. For instance my wife is extremely sensitive to color differences and she picks out things other people might not see. And that's across the color spectrum.
I know you've seen the last screen grab I posted - like I said it looks nothing like your MIDI editor screen. The header for instance is WAY different than mine. I even put back the original dark mode file thinking there was a glitch in mine but it's still the same (aka different than yours). So it's NOT something in my file. BTW when i installed 2020.3 and then 2020.3.1 I liked what Avid did for the track display and grid lines in the Edit screen I left them alone and didn't change them like I did in my first modded dark mode file. If you want my file drop me an email at a regular email address and I'll send it to you.
As you can see in the pic attached, the black/dark lanes are referred to the white keys while the colored lanes are referred to the black keys. Then with some colours this is a bit confusing
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
  #24
Old 04-19-2021, 05:14 AM
I agree - makes no sense. Give me some time to see if I can change that.
edit for additional:
Didn't take long to fix this issue. If you go back to post 15 here where I posted a change to the MIDI editor. What I did was instead of making the change to the cTrackMIDIBackgroundVoicedDark line I put that line back to the stock color numbers. Instead I made the change to the cTrackMIDIBackgroundVoicedLight line using:
40000,40000,40000,65535
instead of the stock:
14135,14135,14135,65535
Here's a screenshot of the new MIDI editor:
Jack
QAPLA!
  #25
Old 04-19-2021, 10:22 AM
Jack - thanks for the offer. I'm juggling multiple projects and can't risk altering the app right now...when things settle down a bit I'd be happy to try it.
  #26
Old 04-22-2021, 10:11 AM
That's because the header you are seeing is from Mac OS Mojave in Night Mode...not a Pro Tools header. When I took the screenshot, that header was included, sorry for the confusion.
Windows Dark Mode FIXED NateAlexander Windows 28 01-24-2023 10:54 AM
Dark Theme file tweaks simonchase Pro Tools 15 08-11-2022 03:34 AM
Stuck in Dark Mode logicioner Pro Tools 2020 18 12-25-2020 04:11 AM
Dark mode onosendai Pro Tools 2018 47 10-22-2018 03:03 PM
