Old 04-29-2019, 02:58 PM
ericsvizeny ericsvizeny is offline
Default Avid hd native thunderbolt question
So just to double check. I need pro tools ultimate and the digilink i/o license to run my hd i/o with my avid hd native thunderbolt box. Can't use standard version pt 12 with digilink i/o license?
Old 04-29-2019, 03:03 PM
Default Re: Avid hd native thunderbolt question
Yes. And this is stated many times over DUC.
Pro Tools HD prior to 12.6 did not need the DigiLink IO license to work with a DigiLink interface. HD/Ultimate has always been required.
Old 01-12-2020, 07:17 AM
nikkeu nikkeu is offline
Hi all, I have a new iMac 2019 OS 10.14.6 and running PT 12.5. I tried connecting my HD Native Thunderbolt through a Thunderbolt 3 to 2 adaptor. There is no light at all on my hardware. I believe even there is no driver the hardware should have a connection? Please advice.
Old 01-12-2020, 07:53 AM
JFreak's Avatar
JFreak JFreak is offline
Hi, welcome to the community.
Yes the power light should be lit when the TB box has power connection.
Janne
Old 01-12-2020, 08:33 AM
Sugarnutz Sugarnutz is offline
You didn't mention which kind of TB2/TB3 adapter. I use an Apple TB2/TB3 adapter without issue on a i9 Hack. The LED indicator is for the integrated headphone amp whether it's on or off.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Old 01-12-2020, 08:55 AM
Southsidemusic's Avatar
Why a TB3-TB2?
you need the opposite for the HDN Box. TB1 to TB3 as the iMac is TB3 and HDN is TB1. I dont think that adaptor will work but I could be wrong of course.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-12-2020, 11:11 AM
JFreak's Avatar
TB1/TB2 is same connector, whether the connection speed is TB one or two depends on the boxes -- if one of them (in this case HDN) is TB1 then the speed is TB1, if both are TB2 then speed is TB2. But the connector is just the same.
Janne
Old 01-12-2020, 11:46 AM
Got it! I know how TB speeds work. We use TB interfaces daily but the OP said he used a TB3 to TB2 adaptor which is wrong if he wanna use a TB1 to TB3 connection here.
HDN = TB1
iMac = TB3
So he needs a TB1/TB2 to TB3 connection.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 01-12-2020, 03:38 PM
LDS LDS is offline
HDN = TB1
iMac = TB3
TB3 to TB2 is just what they are called. https://www.apple.com/au/shop/produc...bolt-2-adapter
Apple-centric labelling of an adapter that I suppose is bidirectional, but man does it mess with my OCD... like when someone explains audio connections in the opposite direction to signal flow. Monitors are plugged into the monitor controller with XLR cables and the monitor controller is plugged into the interface...
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 01-12-2020, 03:57 PM
Thank You LDS for the explanation. I agree it messes with the mind and I start to feel sick and sweat prefusely when things are labeled incorectly like that! Really weird but again Thanks for the Info and good to see you again. Been a minute since we saw you here
Best Regards
Christopher
#thestruggleisreal
WEBHOME
WTB: Avid HD Native Thunderbolt Meads Buy & Sell 1 11-06-2018 05:08 AM
Avid HD Native Thunderbolt and Thunderbolt Cables. SoundEng1 Buy & Sell 0 10-30-2018 10:24 PM
Question on Avid HD Native Thunderbolt Core Joe Courtney Pro Tools HDX & HD Native Systems (Mac) 9 01-22-2017 11:42 PM
FS:Avid Thunderbolt native SoundEng1 Buy & Sell 0 10-15-2016 10:41 AM
Anyone using New Mac Pro with Avid Thunderbolt Native box? johnnyv Pro Tools HDX & HD Native Systems (Mac) 7 06-10-2014 07:14 AM
