Old 04-09-2021, 12:38 AM
rossi68 rossi68 is offline
Default Audiogridder
Have anyone tried audiogridder with the new PT version?
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100
Old 04-10-2021, 01:06 AM
danyg danyg is offline
Default Re: Audiogridder
I had to google to know what this is LOL
Is it basically like the WAVES Soundgrid Server but open source DIY?
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 04-10-2021, 07:00 PM
Benny_Cha_Cha Benny_Cha_Cha is online now
I tried it the other day with Sampletank and it didn’t work.
Did get the computers to connect. Didn’t have time to mess around with it.
Also I didn’t realize that you need to have both machines authorized so two licenses needed for any plugin you want on both systems. Two ilok etc.
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive,
Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 04-10-2021, 09:17 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Wow, that is amazing.
Installed it and it works on Pro Tools and Logic. At least I can see all the stuff. Have to play around with it a bit to see if it is useful.
One thing it doesn't like is WiFi. The second machine running the server needs to be connected via Ethernet.
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 04-11-2021, 11:15 AM
Carl Lie Carl Lie is offline
I had to look it up as well. Cool idea. I think anyone who wants to use Acoustica plugs may get a lucky break doing it with another server.
Curious about the latency.
Thanks for bringing this up.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 04-11-2021, 03:49 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Unless I'm seriously mistaken, I believe you would want the plugins on only one computer. Messed with it a little, but couldn't connect properly. i need to have more time to check it out. Looks very promising though.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 05-24-2021, 01:13 AM
lesbrunn's Avatar
It is amazing. Very similar to using VEP on a server computer, but you actually see the plugin in your DAW as if it were opening locally. It uses no CPU from the DAW side of things. Even VEP consumes a little CPU from PT.
After the initial battle of trying to understand the software, I'm getting to be very happy with it. There are a few glitches, but I believe with time it'll all be ironed out. There are issues with two or three specific plugins, and it doesn't seem as smooth as VEP when it comes to VI's, but it's very very promising indeed. Still messing with it, trying to get a smooth workflow.
Old 05-24-2021, 06:32 AM
Has anyone gotten this to work with sampletank?
Ben Rubin
benrubin.com
Old 05-24-2021, 11:24 AM
lesbrunn's Avatar
OK. I'll try and see. Like I mentioned, there are a few plugins it doesn't work well with.
Old 05-24-2021, 11:26 AM
lesbrunn's Avatar
C
Works well with most of the Acustica plugins I have but there are a couple that haven't worked for me.
