#21
Re: MIDI notes out of sync caused by Delay Compensation?
This one at least seems logical to me in that the audio is coming in late due to unavoidable latency from the computer to the keyboard, then from the audio making its way back into Pro Tools.
Pascal Garneau | IMDb |
#22
Yes I accept the 95ms delay, but why would it increase with delay compensation on to 1100ms, particularly when there’s nothing to compensate for?
#24
Ok, I opened a support case with Avid so we'll see what comes of that.
In the meantime, still trying a few tests. Strangely enough, I used the Commit function to render some midi notes that are too early on the timeline and the notes in the rendered file are actually LATE! I don't know WTF is going on.
#25
For this particular problem, I logged following case back in January 2017: Case 03120087 - Instrument Track Commit results in huge audio delay - Case Closed - Bug Logged/Known Defect - 1/8/2017 |
#26
My method is record midi, commit, and then nudge it until it sounds somewhat like what I played. Good times. :-|
#27
Just forget about serious MIDI-based composition and production in PT. It's not fit for purpose.
#28
I guess one workaround is to pencil a few notes to the grid, Commit, then measure the difference so I can nudge the audio later after I perform a part.
#29
Yeah, as long as you can be sure that difference always stays the same constant value. With Tools, who knows...
#30
Do you guys have any luck if you go into prefs/midi tab and ensure 'global midi playback offset -10,000 to 10,000) is set to zero (0)?
I was having similar issues with Superior Drummer 3 commits, out of the blue where they were fine and perfectly on time with the midi previously. I tried everything, reimported data into a new session to re-commit etc, disabled all plugs except SD3, disabled all sends, tried heat on/off, delay comp on/off... nothing worked except I had -3000 or something in the above parameter that I swear I never changed. Maybe a bug is setting that randomly even if you had it on zero previously. Go check, it MIGHT work. After putting it to '0' my SD3 commit is perfect again. |
Pro Tools 11 Sync issues, OMF's and delay compensation | RedEyeJedi | Post - Surround - Video | 20 | 11-06-2016 05:56 PM |
Keeping Laybacks in Sync (delay compensation and Video sync offset) | edit machine | Pro Tools TDM Systems (Mac) | 6 | 11-15-2010 11:33 AM |
Delay Compensation and sync io | seanob99 | Pro Tools TDM Systems (Mac) | 1 | 03-13-2008 06:44 PM |
Delay compensation and Sync | TLmix | Post - Surround - Video | 3 | 01-09-2006 08:31 AM |
Lip sync and delay compensation? | Erik Olsson | Post - Surround - Video | 0 | 09-13-2005 07:20 AM |
