#21
Re: PRO TOOLS 8 compatible with WINDOWS 7 someday?
But it feels so good when you stop!
~2004 - Dell 4600 P4 3.0GHz, 2.0 GB Ram, XP Home SP3, 80GB HD for System, 120GB HD for Audio BIAB 2009, Pro Tools 8.0, MBox 09/12/2009 - Dell XPS 435T/9000 i7, 6G Ram, Vista 64 Bit 750 G SATA for System, 1TB SATA for Audio, Protools 8.0.1, MBox 10/31/2009 - Win 7 64Bit MBox /PT not supported under Win7 - I didn't leave PT, PT left me! 11/30/2009 - MBox, REAPER http://www.jazzmandan.com |
#22
I was able to install PT8 with an MBOX 2 Pro on a Windows 7 64 bit machine. It worked fine until my computer went into sleep mode. It now does not work even after reinstall and system restore. ????
#23
Check energy setting
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
#24
"Maybe I'm crazy, but I find patience easier than beating my head against the wall.......
But it feels so good when you stop!" My old computer tech used to say, beat your head against the wall long enough and SOMETHING will cave in. But it usually ISN'T the wall...... |
#25
I just completely uninstalled pro tools 8 including any registry remnants. I re-installed and even reinstalled my TI fire wire card and connected the mbox 2 pro to a different port (3 available). Same issue as before. Pro Tools will load as the mbox is powered and detected. The mbox control panel will load and detects the mbox. I cam change normal parameters including buffer size. Pro Tools will record audio from the inputs, but output is not functional. The sound panel in control panel recognizes all inputs and outputs like vista does. When I open a sound program ie pro tools, itunes or right click on outputs 1-2 in the control panel and hit test, the AUX In light flickers and I hear crackling though my connected monitors. It seems like the sound card is trying to output audio but something is preventing it from happening. All this happened after I had a completely working Win 7 64 bit system and my machine went into sleep mode. What could sleep mode done to my system to render it dysfunctional. Any help appreciated.
#26
Avid Updates Pro Tools 8 with First Support for Windows 7 64-bit, and Apple Snow Leopard Support
http://musicindustrynewswire.com/200...583_183301.php |
#27
You should have all your power schemes set to "Always on" and disable all screen savers anyway. |
#28
WELL FOR ME I GOT A HP ELITE SERIES 64 BIT ,6GB OF RAM, 3 HDD, WINDOWS 7 64 BIT AND I FIGURED HOW TO GET IT WORKING PERFECT FOR ME..
FIRST, I GOT THE UPDATE FOR WINDOWS FOR PT.8 http://www.digidesign.com/index.cfm?...4&itemid=40394 if you got the password cool if not that sucks.. SECOND, I HAD ALOT OF PLUGINS I USE ON MY OLD 7.4 LIKE IK MULTIMEDIA,FAIRCHILD 660 , N SOME OTHERS IN WINDOWS 7 THE HAVE THE COMPABILITY BUTTON FOR YOU.. YOU HAVE TO RIGHT CLICK AND TROUBLESHOOT COMPATIBILITY OR JUST PUT IT IN FROM PROPERTIES IT ALWAYS GOES TO XP SP 2.. I EVEN PUT PT.8.0.3. ALSWELL..JUST GOT DONE RECORDING N MIXING SOME OLD SONGS WITH MY PLUGINS I HAVEN'T USED IN MONTHS..IT WORKED.. TRY THAT OUT. IF YOU DON'T HAVE WINDOWS 7 I SUGGEST TO GET I HAVE LINKS IF ANY ONE NEEDS LET ME KNOW.. |
#29
Hey Rusty, You ever get the IK Multimedia installed? I'm wondering because I've had a heck of a time tryin' to get Amplitube 2 installed on my Asus G60 vx laptop which runs Windows 7 with IE8... The IK tech folks mentioned you need to install running as Administrator, and I did that, but still no luck... Just wondering how it turned out for you.
#30
So from my understanding, if I upgrade to PT 8 I can then use the beta which will allow me to use PT 8 with windows 7?
What do I have to download to get my computer to work with my MBox2? I have an HP Elite and right now my MBox2 won't even light up when the USB is plugged in. |
Pro Tools 8 MP compatible with Windows 8? | Darth Strings | Pro Tools M-Powered (Win) | 17 | 01-26-2014 06:08 AM |
Pro Tools MP 9 compatible on Windows 8? | leobastin | Pro Tools M-Powered (Win) | 8 | 01-05-2014 08:00 PM |
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? | VonHelvete | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-28-2010 10:01 AM |
m box usb 2.0? maybe someday? | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-21-2004 01:39 PM |
24bit, 96k someday? | Peter Steinbach | General Discussion | 0 | 04-28-1998 01:33 PM |
