Old 09-08-2018, 06:15 PM
jakedavis jakedavis is offline
Default Re: X-OR record, is it possible?
Ya but then I have to enable that... almost never want to use it so would be constantly toggling on and off. Same as just remembering to disarm the track in the first place.
Really crazy that it can't be toggled in preferences.
Originally Posted by RyanC View Post
If you enable midi merge, midi tracks won't record over themselves.
Old 09-24-2018, 07:40 PM
HearInc HearInc is offline
Can anyone explain why you'd want it to function the way it did for so long, and now does again? I can't come up with a reason why you'd want to have Audio Tracks not latch but keep an instrument track enabled.
I'm going back to 2018.4 for this issue.
Brian Steckler, Producer
PT 12 selects record-enabled track or its section for edit after record pass dktstudio macOS 0 01-06-2018 08:29 AM
Session must be on an audio record volume if permmited set the volumes to R record lionandthemouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-11-2013 01:48 PM
Record 1 audio track, then go to record a second, the timer button flashes... help tdubthatsme General Discussion 5 02-27-2011 04:39 PM
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts The Muphin Man Pro Tools SE and Essential (Win) 8 09-10-2010 07:03 PM
Master Record button doesn't record arm MIDI tracks? Borg ICON & C|24 1 10-29-2007 07:39 AM
