  #121
Old 01-26-2020, 04:58 PM
innesireinar innesireinar is offline
Default Re: Sample Rounding Issue!!!!
Originally Posted by foxes View Post
It's totally ridiculous that this supposedly 'industry standard' is complete crap when arranging midi compositions......their time is ticking with me and my wallet!
This issue is worst than the AAE errors. Last week I formatted the partition where PT 11 was running on yosemite because of the drop of the NI (and others) support. PT 11 was unaffected from this error on midi clips and was useful for arranging songs without having to do with this.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
  #122
Old 01-27-2020, 11:01 AM
foxes's Avatar
foxes foxes is offline
I'm so frustrated with Avid for not rectifying this incredibly long standing PT bug......and no other DAW suffers from it, so it is definitely fixable!
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
  #123
Old 01-27-2020, 02:37 PM
john1192 john1192 is offline
i have PT11.3.2 loaded here ... on Mohave ...
are you saying that the Sample Rounding is NOT happening in PT11 ??? that it started with PT12 ???
thx for the info
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
  #124
Old 01-27-2020, 04:35 PM
PMF Media PMF Media is offline
Well, I'm going to say that for me it started when PT started it's transition to full 64 bit (PT11) I have pretty much abandoned MIDI in PT (I do it all in Logic and mix in PT) but the issue also exists in audio and - it may be my imagination - but it seems to be getting worse/more noticeable with each update, don't believe me? try duplicating a clip or region 3 or 4 times on the same track, using command+D parks/shuffles the clip directly behind the original, as I said do it 3 or 4 times, view it in grid mode and then zoom in to the gaps between the clips to how far off the grid the clips are.
Always worked perfectly back in PT 10 and before.
  #125
Old 01-27-2020, 05:07 PM
thx for the info
Yes but the hd driver v11 doesn't work on sys newer than yosemite. Also tried newer hd drivers with pt11 with no success
Btw I' ve never seen this error in PT11 (and older) on midi clips. Yes there is always been on audio material
  #126
Old 01-27-2020, 05:09 PM
thx ... and sad
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
  #127
Old 01-27-2020, 05:15 PM
I would try to work at 48khz to see if this is less invasive given that there are some bpm tempo that beats match exactly the sample at 48
  #128
Old 01-28-2020, 06:06 AM
foxes's Avatar
I have been working at 48Khz for the last couple of years. There are certain tempos at that sample rate that do not have this issue due to a mathematical division between tempo & sample rate. I remember seeing someone on here posting a list of the tempos which had no midi & audio sample rounding at 48khz.
It is just ridiculous that PT is still the ONLY DAW where this is the case. We can't be limited to working on projects at specific tempos & sample rates.
  #129
Old 01-28-2020, 05:48 PM
Yes, if you run a session at 120 bpm you will have 60.000 (ms x minute) /120= 500. Then you will have 500 ms every beat (4th). When working at 48KHz you have 48.000 samples per second and at 120 bpm 24.000 per beat. PT has a midi resolution of 960 ticks per beat
This means that you will have exactly 25 samples per ticks. Every tick will fall into a integer sample. Working at 60 bpm you will have 50 samples per tick, while at 240 bpm 12,5 per tick then the issue could show up. I think that a daw shouldn't work in sample base when treating midi material. Midi and instrum tracks work always in sample base, even when set to tick. The only difference is that when set in sample the events remain in a fixed position when changing tempo. Just my thought
  #130
Old 01-28-2020, 07:07 PM
this makes a lot of sense ...... in this way ....
1) Pro Tools - began as an AUDIO only platform ... and brought Midi capabilities ... and it is weaker than most in Midi ...
2) Logic, Cubase, etc ... began more as Midi related platforms .. and brought in Audio capabilities ... i cannot say that the other programs are Weak in Audio !! only makes me bummed that i learned Pro Tools 1st .. as it is not as easy to get around Audio in Logic as PT .. and only because i have PT burned into my brain .. a little Electro Shock and i shoud be able to unlearn all this PT crap !! ha ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Sample Rounding budda963 Pro Tools 11 1 07-08-2013 06:07 AM
sample rounding error in pro tools 10??? DarkDayz Pro Tools 10 6 11-02-2011 03:22 AM
PT and Sample Rounding WILL cause Issues when Copying 25ghosts Pro Tools TDM Systems (Mac) 7 07-01-2011 02:25 AM
Sample rounding issues bigdoghat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-13-2007 08:20 AM
Sample rounding, ticks, etc voce Pro Tools TDM Systems (Mac) 1 08-03-2005 05:26 AM
