iLok Issue...Still
Contacted iLok support last week due to the fact that my iLok licenses for plugins would not recognize mid session, then less than a minute later, they would be recognized but I could not add a plugin to a track until I close and restart ProTools.
iLok recommended that I install the latest iLok manager (which I already have) and problem should be solved.....Nope! Still happening Anyone else having this issue and figure out a work around? Thanks! |
Re: iLok Issue...Still
Transfer licenses to the cloud and see if this still happens. If not its your iLok.
What Darryl said Or you have your USB ports set to sleep after a certain time has lapsed. Look at the settings for power daving or energy saving and see f you have your ports set to goto sleep.
Thank you both for your response. Some of my licenses won't allow the iLok cloud. That's unfortunate because I think they all should be compatible.
With regards to the USB ports, I checked in System Prefs/Energy Saver but I didn't see anything listing USB ports, only hard drives. Where do I find that? Thanks again! |
Just move PT and license that is giving you a problem to the cloud. Why do the others even matter? You are trying to troubleshoot if the iLok is bad or not, and rather quickly maybe before you are stuck up a creek with a dead iLok...
Thanks for the suggestion, however it's not just a single license that's causing the issue. Once I restart Pro Tools it works fine. I'm starting to wonder if it's a iLok comp issue with either PT 2018 or Mojave
This is not rocket science. Just put all the licenses you can in the cloud and just see if you have *any* problems there. If not then replace your iLok, move other licenses or all of them to your new iLok. Your problems are your problems... your install or (quite likely) a faulty iLok. You need to troubleshoot your issues. Nobody else can help you. There are no general known problems, if there were DUC would be ablaze with them.
And it looks like you are on a Mac, so you don’t have all the Windows USB power settings, but do all Mac optimizations and test with iLok using multiple different USB ports, remove all other USB peripherals you can (including any USB interfaces... test with Built-In Output if needed) and test with the iLok in a powered USB2 hub, all to look for faulty Mac hardware.
ilok issue | pasanta | macOS | 4 | 05-23-2012 01:10 PM |
Hi all.. I have an iLok issue. | NSP | macOS | 10 | 04-08-2011 09:04 AM |
iLOK issue | DonaldM | Virtual Instruments | 8 | 12-19-2007 01:49 PM |
the issue of iLok.com | Captain Crunch | Pro Tools TDM Systems (Mac) | 5 | 08-04-2004 01:04 PM |
