Re: mouse causing massive cpu spikes
IMNSHO Dynamic plugin processing likely never actually helps and may occasionally cause problems. Just turn it off.
From the Sandra report:
laptop with dual graphics... make sure the discrete GPU is *always* enabled and all the laptop power management crud is turned off. Hopefully that MyPassport drive is only for backup. It will be slowwww and unsuitable for audio or samples. |
The dynamic plugin function works very well for me, as soon as i uncheck it i get a large increase in my cpu so I don't see the point in having it always off if it's not causing me any problems and benefiting me. I'll experiment with it. Are you saying it's a buggy process that protools does not implement correctly?
Yes the WD hhd is for back up only. The two t5's are for audio and samples. Power managment crud is all off. Minimum and maximum processer state is 100% No power saving for any hardware enabled. The nvidia gpu is always on when running protools. Thanks |
if it’s working for you then great. But “get a large increase in your CPU” as in the CPU meters move more is not that useful (just stop looking at CPU meters) vs. what actual changes in what you can run i.e. AAE CPU errors vs IO buffer sizes.
Giving the illusion of helping by lowering the CPU meters... that part is simple and it sure can do that. Sounds like all you can do now is get with EW on these issues. |
003r PT11 Massive CPU spikes | jimmy3189 | FireWire & USB Audio Interfaces (Mac) | 2 | 03-06-2017 12:28 AM |
Waves plugin and mouse causing CPU spikes | simonyeah | Pro Tools 10 | 13 | 12-30-2014 05:21 PM |
Avid Pultec EQP-1 Causing cpu spikes | Shifted Music | AAX Plug-ins | 6 | 08-11-2014 07:52 PM |
NI Battery causing CPU spikes - why? | timmy4402 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-30-2005 11:56 AM |
