Old 11-17-2020, 11:34 AM
Rectifried Rectifried is offline
Default OffLine BTD always hangs at the end
Ok.. PT were getting close to a better daw..
But my BTD is topping at 1.5x offline speed.. and always hangs and I have to quit
since its barely above realtime I just do realtime.. Long process for stemming 5 stems per trk
I did have ozone9 and thought that was it but even using old waves L2 same deal.
I thought we were almost past endless restart error ..
CPU dbl middle cores and Red bar pinned BS.. buuuuut No
anyone else?
or am I the luckiest chump
12core 64 g ram.. clean install no wifi running
PT is a finicky ---
Hal Cragin On the DUC Since The Year 2000 AD
Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2]
Old 11-19-2020, 05:16 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: OffLine BTD always hangs at the end
Try turning off the new pad frame boundaries in bounce dialog.
Old 11-20-2020, 03:06 PM
it was off.. thx tho
Old 11-20-2020, 03:37 PM
I'd be looking at plugins. If an off-line bounce is going at 1.5x, then some plugin(s) is causing that. For me, its usually something like KeyScape, so I tend to commit those tracks early on.
Old 12-02-2020, 06:35 PM
musiccog musiccog is offline
We recently updated one of our systems and have been experiencing this too.
This is what we have running on that machine if anyone has any suggestions:
- Mac Pro 2012 Xeon 24GB RAM, OSX Sierra 10.12.6
- Pro Tools HD 2019.6, HD Driver 2019.6
- AIR Creative 11.3.1, Latest Waves Central, T-Racks, soundtoys
Old 12-03-2020, 03:27 AM
Will Russell's Avatar
Will Russell Will Russell is offline
My experience is that this is most likely caused by a plugin. Last time I had this problem it was Lexicon PCM Native Reverb.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 12-03-2020, 05:24 AM
marsian marsian is offline
We had the same problem.
It turned out, that it was caused by a active rewire plugin in the sessions (for Videoslave).
Cheers
Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D
mars13.de
Old 12-05-2020, 06:02 PM
Having a few plugins ...it’s always wAck a mole ... other daws seem to deal way better w same plugins ... why is that
Old 01-04-2021, 01:42 AM
Found the culprit:
T-RackS 5 on a stereo track (not master..)
When removed, export speed (on an HD system) went from 3x with a massive lag at the end of the render, to about 60x and no lag.
Will raise an issue on their forum.
Thanks for the ideas.
PT hangs after initiating offline commit or bounce Mano Pro Tools HDX & HD Native Systems (Mac) 6 11-06-2017 01:19 PM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
Hangs in on DUC Josetimbal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-15-2012 09:53 PM
003 LE hangs says 003 offline jonw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-08-2008 10:33 AM
PT 5.0 .....just hangs sometimes SWAT Pro Tools TDM Systems (Mac) 1 01-10-2000 03:20 PM
