Old 12-03-2020, 08:35 AM
XJENSEN XJENSEN is offline
Default Nudging, trimming, sliding clip content, etc. don't work
I'm having a problem. Simple nudging of clips works fine with either , and . or - and + on the numeric keypad.
  • Nudging selection start/end points with Option+Shift does not work.
  • Trimming with Option does not work.
  • Nudging contents of clips with Control doesn't work.
I'm in keyboard edit focus. Preferences have numeric keypad set up in classic mode.
Any ideas?
Old 12-03-2020, 08:41 AM
Default Re: Nudging, trimming, sliding clip content, etc. don't work
I think I got a hunch. Forgot to mention that I have a separate numeric keypad. When I open keyboard viewer, it seems that the numeric Enter key is not sent as it should be and regarding the problem above, the modifier keys may not apply to what I press on the numeric keypad (- and +)...
Old 12-03-2020, 09:05 AM
By searching the DUC further, I have found this thread: Default Shuttle Lock Speeds with Bluetooth Numeric Keypad.
It seems that my keypad does in fact send the correct values, however the modifier keys aren't caught correctly.
I have this one: NewerTech NWTKPA2 8BTW Numeric Keypad Numeric Keyboard.
Is there a way to fix this, maybe in macOS?
Old 12-03-2020, 10:14 AM
Solved, using Karabiner!
Excellent description can be found here: https://www.scoringnotes.com/news/us...and-karabiner/.
Trimming a clip to end or start the same as another clip ikjetil Tips & Tricks 2 08-01-2020 06:56 AM
Sliding a MIDI clip problem SomeOtherGuy Pro Tools 2018 2 05-03-2018 11:54 AM
Pro Tools 2018 crashes w/ clip sliding Mistakeys Pro Tools 2018 5 02-17-2018 12:13 PM
Nudging a clip past another clip removes the stationary clip evil.beasts Pro Tools TDM Systems (Mac) 0 11-01-2017 11:08 AM
Nudging regions content in PT 5.0 Kenshiro Pro Tools TDM Systems (Mac) 2 11-26-1999 01:35 PM
