Old 11-23-2012, 11:42 AM
franco412 franco412 is offline
Post MOTU 4Pre and Pro Tools 10 on Windows 7
Is anyone out there using two or more 4Pre's simnultaneously as there I/O device? I'm having an issue where they will not work in tandem. I can run one or the other but not both simultaneously. Whichever device is set up as the slave under the MOTU Audio Console will not sync with the master. I.E. the sample rate light starts blinking as soon as I open either CueMix or Pro Tools. Something I've noticed is that when I use only one 4Pre and look at the device settings at "Control Panel > Sound > Playback (or Recording) tabs > Advanced" the avaliable sample rates include both 16 and 24 bit depths. However when I try to utilize both units I have only 16 bit depth available for the listed sample rates. I record at 88.2, 24 bit. I'm using USB 2.0 ports on the 4Pre making quite sure each unit is using it's own dedicated Enhanced port (not USB 1.0 or USB 3.0 port) to the PC.
Thanks, Franco
Sandra Report:
Computer
Model : MSI MS-7640
Chassis : MSI Desktop
Mainboard : MSI 890FXA-GD70 (MS-7640)
BIOS : AMI (OEM) V1.15 10/31/2012
Total Memory : 16GB DIMM DDR3
Processors
Processor : AMD Phenom(tm) II X6 1090T Processor (6C 3.6GHz, 2GHz IMC, 6x 512kB L2, 6MB L3)
Socket/Slot : AM2r2/AM3
Chipset
Memory Controller : AMD F10 Athlon 64/Opteron/Sempron HT Hub 2x 2GHz (4GHz), 2x 8GB DIMM DDR3 1.33GHz 128-bit
Video System
Monitor/Panel : ACR Acer S231HL
(1920x1080, 23.1")
(1920x1080, 23.1")
Video Adapter : NVIDIA GeForce GT 520 (48 SM5.0 1.62GHz, 1GB 1GHz 64-bit, PCIe 2.00 x16)
Storage Devices
Seagate ST3000DM001-9YN166 (3TB, SATA600, 3.5", 7200rpm) : 3TB (C:)
Seagate ST3000DM001-9YN166 (3TB, USB3/SATA600, 3.5", 7200rpm) : 3TB (S:)
TSSTcorp CDDVDW SH-222BB (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
WANTED: Focusrite Liquid Channel or 4Pre al-andrew Buy & Sell 0 12-18-2013 02:17 AM
WANTED : Focusrite Liquid 4Pre al-andrew Buy & Sell 0 12-07-2013 11:03 PM
anyone tried focusrite428 or liquid 4pre? Greene Pro Tools TDM Systems (Mac) 4 06-29-2008 08:00 PM
Pro Tools LE and Motu 828 EnjoyFailure 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-19-2002 02:21 AM
Pro tools 001 vs MOTU DERQ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-08-2000 09:17 PM
