Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 06-21-2007, 02:09 PM
PT-MP Rookie PT-MP Rookie is offline
Default recording vocals in mono or stereo?
which is best? & why?
Also, what does it mean when you only get audio in one side of a stereo track?
Old 06-21-2007, 03:09 PM
spkguitar's Avatar
Default Re: recording vocals in mono or stereo?
Understanding what Stereo tracks/signals are really would make this question unnecessary, so I will explain that to you;
A stereo signal is made up of two independent audio channels that are blended to create the illusion of spatial direction. Stereo tracks contain two separate independent audio files.
If you are rcording vocals with a single microphone, you only have one audio source and can only record one audio file, thus should be recording to a mono track.
If you were using two microphones to record the vocals, you would have two audio sources, and could use a stereo track if you wanted to.
Typically, vocals are recorded in mono, and then panned into the stereo spectrum appropriately during the mixing process.
As I mentioned above, when recording a stereo track, you are recording two audio sources. You will notice that when setting up a stereo track, the input selector is set for two inputs, either 1&2, 3&4, 5&6, etc. If you are using a single microphone to record your vocals, you are recording a mono source using only one of those inputs. You will also notice that the pan indicators on the stereo track are set fully left and fully right. When you are recoding a single, mono source to a stereo track, the data that you are recording is only going to one track of the stereo track, and that track is panned fully left or right.
Understand?
Old 06-21-2007, 05:22 PM
yes indeed my friend, you the man buddy. Thank you kindly. out.
Recording vocals in stereo or mono djmichael.london 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 03-19-2009 11:03 AM
Recording Vocals Mono or Stereo rcourell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-24-2005 08:41 AM
Vocals: mono or stereo? MrLive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 02-24-2004 10:30 PM
Stereo vocals from mono source... Xray55 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-05-2002 03:56 PM
VOCALS : record in stereo or mono?? marilyn manson and the spooky kids 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-02-2002 10:16 AM
