Old 12-02-2017, 04:55 AM
TheGuitarGrandpa's Avatar
TheGuitarGrandpa TheGuitarGrandpa is offline
Default 11r and MAC High Sierra Issue
My Eleven Rack keeps becoming unrecognized when Mac goes to sleep and is only reconnected when I restart. I’ve tried reinstalling the drivers and all to no avail. Anybody got any recommendations on how to keep this from happening?
Old 12-02-2017, 05:06 AM
Southsidemusic's Avatar
Default Re: 11r and MAC High Sierra Issue
Here is one - Stop using any sleep feature whatsoever when you work with audio.
This has been talked bout for ages and putting drives, computer etc to sleep is a NO NO and that is also outlined in the optimization section on Avids website aswell as here : http://duc.avid.com/showthread.php?t=300050 where you should look before posting here.
So turn OFF ALL sleep and powersaving options if you use the computer for audio.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-13-2017, 11:17 AM
147235 147235 is offline
I don't think OP is suggesting he is leaving audio sessions open while putting his mac to sleep. I use the Eleven Rack as my primary interface and experience the same issue on Mac OS X Sierra 10.12.6. The Eleven Rack will only connect to a Mac if you restart and wait to connect until start up is complete - on a good day.
I just spent the last 20 minutes restarting my computer over and over. I tried every USB port, with and without a USB hub, even tried different USB cables. Finally connected after the 5th attempt. Super frustrating.
The problem is not the Mac user for using their computer as intended. The problem is Avid for not figuring out a basic user case.
Old 12-13-2017, 11:32 AM
Yeas your right it has nothing to do with putting the computer to sleep while using an audio program. Its Avid's driver issue I believe.
Old 12-13-2017, 11:34 AM
No one is putting the computer to sleep while using an audio program. But thanks for the smartelic reply thats what people are looking for.
Old 12-13-2017, 11:51 AM
+1
Old 12-13-2017, 12:36 PM
You write after the computer goes to "sleep" in your post so one would say thats why it is a problem even if you don't have PT open. The audio interfaces like 11r will loose connection as soon as the computer sleep as you say yourself.
If i missunderstood that I am sorry but just reading what you said ..
And i never said while using audio programs, it is the whole computer and doesn't matter what is open or not.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 12-21-2017, 02:59 PM
Pingafuego Pingafuego is offline
Eleven Rack is now supported with Mac OS High Sierra 10.3.2
http://avid.force.com/pkb/articles/e...13-High-Sierra
Old 01-20-2019, 08:44 AM
vernon vernon is offline
sudo killall coreaudiod
this command will force core audio to restart, just had my audio drop in the 11R and did this command in terminal, its back up. Ive been on the hunt for terminal commands to drop and restart the 11R, but im thinking this is also a core audio ordeal, and im not certain that the 11R is really meant to be used without a host interface. If it were then the driver might stay engaged even after sleep mode
Music Production Bachelor of Science, Fullsail Univeristy, 2016. Mid 2012 MacBook Pro, Eleven Rack , ProTools , Logic, Sibelius, etc.
Old 02-01-2019, 09:31 AM
DonaldR DonaldR is offline
Will try for sure. Thanks
S6L AVB with OS X High Sierra brinnbacka VENUE Live Sound Systems 3 10-20-2018 12:52 AM
High Sierra jeffpardo Pro Tools 12 28 12-20-2017 09:39 AM
High Sierra jon9 Eleven Rack 0 11-16-2017 03:35 AM
High Sierra yet? mlavin00 Pro Tools 12 18 11-13-2017 10:09 AM
12.8.2R2 on High Sierra TrentWilliams Pro Tools 12 3 10-21-2017 10:09 PM
