Old 06-18-2003, 05:59 AM
Kendo Kendo is offline
Default PT 6 Mac Os X Digi 001 and MIDI interface
Hi :
Is there anything wrong with PT 6 Mac OS X and the midi interface from the Digi 001 hardware?
Though the audio part works properly, there's no way for me to make the MIDI interface work.
Thanks for your help
Old 06-18-2003, 07:10 AM
gigi gigi is offline
Default Re: PT 6 Mac Os X Digi 001 and MIDI interface
I have the same problem.
I've installed the Core Audio Driver, but I have uninstalled it. During uninstalling process I received a warning that says that some components couldn't be remove.
May be that that is the problem.
How can I do?
Any ideas?
Thanks in advance
Gigi
Old 06-18-2003, 07:27 AM
AverageJoe AverageJoe is offline
Yeah, I'm in the same boat- tried to uninstall core audio and still can't get MIDI to work via 001.
Digi, can you give us a step-by-step process for uninstalling C.A. and gaining Midi control back?
Old 06-19-2003, 12:47 AM
Please Digi, could you help us?
Grazie
Gigi & C.
Old 06-19-2003, 06:17 AM
carouzal carouzal is offline
When core audio is installed the installer moves the 001 MIDI drivers to a seperate folder. It say something like moving unused drivers to /Applications/Digidesign/Unused Drivers or something similar. Try moving that driver back to the original location or reinstall Pro Tools after removing core audio. Even better pick up an external MIDI interface and have the best of both worlds or "Wait" for digi to fix the problem with core audio and it's MIDI drivers.
Hope this helps.
Dual G4 1.42Ghz, Gig of Ram, 001, OS X 10.2.6
Old 06-20-2003, 01:48 AM
Thank you carouzal , everything is ok now. I put the DIOOSXMIDIDriver.plugin back in "Library/Audio/MIDI Drivers " Folder and it works.
Thank you very much
Ciao
Gigi
does Digi Pre need an midi interface? digidesigner Pro Tools TDM Systems (Mac) 1 11-24-2009 01:52 PM
using digi 002 as midi interface three2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-25-2008 08:20 PM
DIGI 001 and USB MIDI interface Bobbi Tube 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-10-2005 10:22 AM
Digi midi interface tnie Pro Tools TDM Systems (Mac) 0 02-08-2003 01:06 PM
Digi 001 and new HD Midi I/O interface JPS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-29-2002 10:29 PM
