Old 11-04-2019, 01:52 PM
midnightrambler midnightrambler is offline
Default Click count vs Main counter for 6/8
Can anyone explain why, when I have a 6/8 meter, the click still stubbornly insists on counting in 3? Can't quite work out if it's me or ProTools that's at fault here.
https://giphy.com/gifs/QBG45ibHC8k0kLe0PW
Old 11-04-2019, 02:05 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Click count vs Main counter for 6/8
It looks to me your main counter isn't 6/8 but hard to say because of there resolution. Just that I am seeing a dot in there, and the click plugin isn't like 1-2 would equal 1, 3-4 would equal 2, 5-6 would equal 3 so double-check that first
Might be a bug as well, but maybe it is a config error
Janne
Old 11-04-2019, 03:03 PM
I don't seem to be able to get it to just click 8ths no matter what I set the values to. It always ends up sounding like a waltz.
https://youtu.be/il_6maP6xQU
Old 11-04-2019, 10:30 PM
_JJ_ _JJ_ is offline
as weird as it seems, try changing the value here.
Old 11-05-2019, 10:23 AM
You set tempo resolution in the tempo event dialog and click value in the meter event dialog. So for a typical 6/8, you'd set your tempo resolution to dotted-quarter, and in your 6/8 meter event set clicks to 1/8th notes.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 11-06-2019, 04:08 AM
Thanks guys.
Never even noticed that option before, thanks. Just assumed all functions would be available within the click plugin itself (I know, silly me).
Not sure why this doesn't work when you deselect "follow meter" in the plug-in though? Why doesn't the plug-in play 8ths when it's set to it - i.e. why doesn't this setting produce the same result? It only clicks 4 times, and then misses out the final 2.
http://duc.avid.com/attachment.php?a...1&d=1573041899
Shouldn't there be an additional "meter" option within the plug-in in order to it to click 6 times instead of 4, if you want it to "not follow the meter" ?
Thanks - this makes much more sense now I've become aware of the click option above.
Old 11-06-2019, 05:19 AM
Also, what is the point of having these light up as quarter notes when they're so patently not? Surely they should display whatever click you're actually hearing?
https://giphy.com/gifs/huhC8hWwsHbVRsoJNN
I'm not sure the GUI on this click plugin has been very well thought out really.
Main Counter: Font Changed Ryan Young Pro Tools TDM Systems (Mac) 2 07-04-2013 07:27 AM
Main Counter doesn't update when I click the timeline Grizz1978 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-25-2011 06:40 PM
Main counter question (pt 8) whitetar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-18-2011 09:46 PM
Main Counter Question RichrdC Pro Tools M-Powered (Win) 0 02-11-2010 09:53 AM
Main counter mode not switching using "counter" switch bashville ICON & C|24 2 08-07-2009 04:07 PM
