Buying an Mbox need guidence---
Hi, I am fairly new to M-powered audio, I have previously been using apple garageband and direct input. I have upgraded to logic express and I was told to get a preamp. Right now I am trying to figure out what the differences between the Mbox 1 and Mbox 2 are. A friend wants to sell me an old mbox 1 for 100$, but I am wondering if it's worth the extra 100 or so to get the mbox 2. Any help would be great!
JeffV-- |
Re: Buying an Mbox need guidence---
Digi just announced they will no longer be supporting the original MBox. So, if you buy the MBox 1, you'll be limited to the current PT release and not be able to update/upgrade to any new PT software.
Look here: http://duc.digidesign.com/showthread.php?t=254166 BTW - M-Powered is Pro Tools for the M-Audio interfaces. You run PT LE on the MBox series.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
didn't you just say you upgraded to logic express? If you're not using Protools I'd recommend the apogee duet or the single version of it... quite cheap and sounds way better than the mboxes
se.audio |
For the money, I think there are much better options (Focusrite, Mackie, MOTU).
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Well I am incredibly confused, how did you all learn this stuff? Are you taking collage courses on it? All I know how to do is make stuff sound good once I've learned the program and I have no idea what I'm doing. Would the mbox 1 be a decent upgrade from direct input? I better go do some reading...
Wow, I was actually looking at the duet and considering it. I was wondering how it sounded compared to their other gear. I 've used the two channel rosetta and loved it so much, but I'll take your word for it. What about the mini-me?
MetalMike,
Don't take my word for it. Go check it out. In my opinion, it is not even close to the Rosetta. The Mini-Me is hard to come by these days.
no.
to be precise digidesign hardware is no good when not used with PT. the digidesign Core Audio Manger which is needed to use digidesign interfaces etc as generic audio device is a piece of coding junk. and mBox 1 drivers will be unsupported very soon unless you keep your system EXACTLY as it is now. anyway if you are using/ want to use PT M-Powered you NEED and M-Audio Interface. mBoxes etc ONLY work with Pro Tools LE! best
last: PT11.3.1 |
but really worth it. excellent piece of dope.
last: PT11.3.1 |
It all depends on your budget and what you are trying to do.
If you want to record a band Mbox2 wount do. You need atleast a 003 for that. If you only record one track at a time mbox2 works ok. |
Advice & Guidence | Buel Pace | Pro Tools 10 | 6 | 11-30-2013 01:41 PM |
Buying a used Mbox 2 | teabaggery | Getting Started | 1 | 06-13-2013 05:50 PM |
Need a little more guidence on this one | Moodyscorpio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-10-2005 10:37 PM |
Looking for some guidence please | Eddie D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-04-2004 04:58 PM |
A little guidence please! | Super Seven | MIDI | 8 | 04-28-2004 09:08 PM |
