Old 11-27-2007, 09:17 PM
rockandroll817 rockandroll817 is offline
Default Quicktime will not play audio through Digi Coreaudio and 002
Ok... im really confused. I installed 7.3.1cs5. I was running 10.4.9 and now i get no audio to digi coreaudio and the 002. everything else uses it just fine: logic 8, itunes, garageband, world of warcraft, vlc. when i play a quicktime movie, it will work fine with built in audio, but when i send the audio to the 002, i see the firewire light come on but nothing comes out. Ive tried updating past 10.4.9 and that did not fix it. any thoughts
Old 11-28-2007, 03:05 AM
Phil Ogden Phil Ogden is offline
Default Re: Quicktime will not play audio through Digi Coreaudio and
Have you updated quicktime? QT 7.2/7/3 have been known to cause problems. A combo OS update might be worth a try
Mac OSX Some Applications may not open after Quicktime Update
Old 11-28-2007, 10:05 AM
DigiTechSupt's Avatar
You could also try trashing preferences, including 'com.digidesign.coreaudiomanager.plist'.
Avid Audio Tech Support
Support FAQ
Core Audio v7.4.2 Driver freezes Itunes 8.2 and will not play in quicktime v7.6.2 852 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-05-2009 10:30 PM
Quicktime will not play on core audio driver?? patrick1307 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-09-2008 11:53 AM
imovie audio won't play thru Digidesign Coreaudio mithranda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-27-2008 11:30 PM
Digi002R won't play audio in Quicktime and PwrDVD barish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 11-18-2005 08:55 PM
No audio output in Logic with digi coreaudio crizdee Pro Tools TDM Systems (Mac) 2 11-07-2005 02:04 AM
