Pro Tools will not open on fresh install: SOLVED
I just did a fresh install of Windows after a format. I downloaded and installed PT 10.3.3 and it installs fine. I go to open and as soon as the splash screen comes up I get the following error:
Could not complete your request because Assertion in "..\..\BDM\BDM_Workspace.cpp" , line 1485. After researching for awhile I cant find this specific Assertion error anywhere. All of the ones I find are close but not exact. The fix for these is to trash preferences. This is a fresh install so there are no preferences. I have uninstalled and re-installed. Same thing happens. Any ideas? |
Re: Pro Tools will not open on fresh install
Maybe your downloaded installer is corrupt?
First thing I'd try is downloading it again (on a fast internet connection). Is v10.3.3 an updater or full installer? A full version must be installed before applying an updater.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Its a full installer. I have downloaded it twice already from the only place there is to download it. Im downloading it for the 3rd time now NOT using the download manager to see if this resolves it.
If you didn't do it already, right click on installer EXE and 'Run as Administrator'.
Try deleting your databases folder.
:: Bharath Pro Tools Software Team |
I just tried to install for 3rd time no luck. Same error. I am uninstalling now and try to run exe as administrator. Thanks for your comments.
This is a fresh install. Would there be anything to delete in data base folders? Just curious.
It shouldn't. But the assert you mentioned pertains to databases, catalogs. I will be curious to see if launching ProTools with "Run As Administrator" fixes it.
You might try downloading Trasher and cleaning up any leftover prefs or databases. I often do this before uninstalling Pro Tools and updating it.
EDIT: Nevermind. I just reread the first post and relized this is a fresh Windows install.
Ok so I finally figured it all out so I wanted to post it here in case anyone has this problem. I first started here http://duc.avid.com/showthread.php?t=334520
I was trying to update from 10.3.2 to 10.3.3. For whatever reason my computer could not find the HD driver to uninstall it so it would never cpmpletely uninstall Pro Tools. So I have a secondary drive (Drive D) that I had cloned Pro Tools onto the last time I did a fresh Windows install last May. So I booted from that drive to try and install 10.3.3 onto that drive. Same issue. It could not find the HD Driver to uninstall it. So I decided to format the D drive and install a fresh copy of Pro Tools onto that drive since most of my important stuff was on my C drive. As noted the install process when just fine, but it would not open because of the assertion error. So I saw a post by Tom@Metro somewhere that said Pro Tools puts database folders everywhere including thumbdrives. And that got me thinking of Beharath who said that this error stems from database folders. So I had the Trasher and used it trash preferences and databases even though on Drive D there were no existing preferences, etc. But what I failed to realize is that Pro Tools never fully uninstalled from my C drive even though it said it was successful in doing so. So I started looking in my Program files in my C drive and sure enough there were Avid and Digidesign folders in there and in the Common files folder. The only problem was, Pro Tools would not delete these. SO after gathering all of my important information from this drive and saving to an external I decided to format it. Then from my D Drive I opened up the Trasher and once again trashed prefs and database. I then emptied my recycle bin and did a restart. Clicked on Pro Tools....Boom! Opened! So in the end this was all due to traces of PT that were left on my C drive. I only posted all of this so if anyone ever had this issue it would lead them here. I had no idea that Pro Tools (or traces of it anyways) on a different drive would affect another drive. Now I know thanks to Tom and Baharath. So Thanks to everyone who contributed. This is an outstanding community. |
Error when launching Pro Tools 11 after fresh install | Syrcular | macOS | 14 | 01-26-2014 01:54 AM |
Pro Tools 8 LE really buggy on a fresh install | rubberhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-21-2012 01:01 PM |
Win 7 Pro Fresh Install - crashes when closing Pro Tools | Monty_python | Windows | 11 | 10-24-2011 08:26 PM |
Pro Tools 9.0.5 freezes after FRESH install of Lion | conrad787 | macOS | 6 | 10-18-2011 06:36 AM |
Fresh install of Pro Tools Le 6.4 | cherrancemetal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-01-2011 10:21 AM |
