Old 04-15-2017, 12:02 PM
francois's Avatar
francois francois is offline
Default Where can i buy a Power Supply for my D-Command ?
My fader pack is starting flashing
I guess it's time for another PS .
I need a contact info for it
I can't find my way thru the Avid site and I lost the contact I use to have when I previously changed the one in the main unit.
Thanks
francois
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
Old 04-15-2017, 10:01 PM
Barry Johns Barry Johns is offline
Default Re: Where can i buy a Power Supply for my D-Command ?
Why do so many Digidesign/Avid gear need power supplies replaced so form?
In all my various gear from many companies, I've never needed to replace a power supply.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 04-15-2017, 11:28 PM
Stig Eliassen's Avatar
Thanks
francois
This should do it.
Equipment list > Create a case (Avid support center)
Old 04-16-2017, 05:41 AM
francois's Avatar
Thanks Stig but your link is Spam (salesforce.com ????)
Iam current with my Avid plan but i do not see any link to my ICON
I have bought 2 power supply and a channel strip in the past for it but lost the phone #
Can someone PM me a working direct line
Thanks
Old 04-16-2017, 05:44 AM
Drew Mazurek's Avatar
I'm going to guess that Digi/Avid sold over 5000 ICONs. Each ICON has multiple power supplies, for things like LEDs, faders, meters etc. So we're talking potentially tens of thousands of units.
We're on a forum where people might report issues like a failed power supply. I suppose you could count the posts by users that mention power supply failures. Not sure if that would yield good data or not. I do know that even things like expensive SSL consoles need power supplies replaced sometimes. It's not uncommon at all.
My ICON has been in use for 11 years (and I leave it on 24/7) and I did have one go bad. I also have an Apogee Symphony I/O that had a power supply fail fairly early on in its life. BTW, the Avid fix I did in the field for a few hundred bucks, Apogee required I send it in and it was $450 plus 2 weeks of lost usage.
But you're right, other than these two times, I've not seen them fail much in other gear.
www.drewmazurek.com
Old 04-16-2017, 07:14 AM
It's way more than Icon. Its Control 24, Pro Control, 002, most threads when talking about buying used many people recommend confirming that they have a replaced power supply.
Old 04-16-2017, 08:06 AM
Thanks
Spam? It should take you to Support Center Login. That's what happens here.
Old 04-16-2017, 01:24 PM
StefB's Avatar
StefB StefB is offline
Thanks
salesforce is the system Avid uses - its not spam....
Mac 16 Core 7,1 -Os 10.15.7 - 96 gb Ram - Pro Tools 2022.6 Ultimate in 5 suites - MTRX Studio -S6 26-5-D - Sync HD - Video Satelite (Symphony 2022.5, AJA Kona 3g) Pro Protools 2022.6 Vanilla in 21 x Recording and Edit suites. Mac 6,1 Mac Mini, Mac Mini M1, Mac Studio Pro, Mac Studio Max
Mediacomposer 2021.12 on AJA Kona 3g / XT I/O x 3 suites. Multiple Avid S1, S3 & Docks
Old 04-17-2017, 10:37 AM
francois's Avatar
OK Avid is using salesforce but after login into the link I got a phone call this morning from salesforce trying to sell me some software...
Old 04-17-2017, 10:50 AM
No luck with these numbers?
http://www.avid.com/learn-and-suppor...-music-support
Or if you're "on plan", you can simply start a case.
www.drewmazurek.com
Command 8 Power supply davpond Buy & Sell 2 12-06-2019 08:06 AM
Command 8 Power Supply question MarkH ProControl, Control|24, Command|8 6 09-20-2017 05:11 PM
Command 8 Power Supply SWAP US for EU psmworld ProControl, Control|24, Command|8 1 09-03-2015 11:29 AM
Command|8 Power Supply? stuseattle ProControl, Control|24, Command|8 5 05-03-2012 04:33 AM
Command 8 Power Supply infernojs ProControl, Control|24, Command|8 3 10-03-2005 12:59 AM
