Application Manager 17.2 stuck on "Initializing"
Today I accepted an update to the "Application Manager."
It gets stuck on "Initializing." It will not Quit. On force quit, it does NOT EVEN SHOW UP. My solution was to throw the application manager into the trash. From the Finder. Then I went and ran the uninstaller. Am I ok. Any thoughts? What's the deal? Oh. And There is No Support on the Avid support site for "Application Manager." It's like the program doesn't exist. Thank you. |
Re: Feb 21 2017 Application Manager Update No Worky
Hi, welcome to the community.
Please read the Help Us Help You page that is linked to the forum header.
It gets stuck indefinitely.
This is the update that went out TODAY, which is why I think it is worthy of a new "thread." So, to be clear, I threw it in the trash while it was "initializing" and refusing to Quit. Then I did a full shutdown and startup. Then I ran the uninstaller. I am beginning to think there is absolutely no need for this program. I have the Application Manager folder still sitting in my trash. |
When you say "a while."
It was stuck for a few minutes. Does "a while" mean more than a few minutes? I should be waiting 10 minutes or an hour for it to stop initializing? I've never really "used" the application manager for anything that I can think of. |
Yes, currently. About 5 minutes is not uncommon, and it is totally not acceptable.
I agree it is not acceptable.
I did not accept it, so I trashed the program using the above methods. I don't think that should affect my ProTools program. I should also mention... it was about 5 minutes doing the spinning wheel as well after I tried to Quit the program. So, not only does it fail to initialize, it fails to Quit. Thank you for your response. |
I've had similar issues in regards to closing the application while it's in 'initialising' mode. It hangs, the only way to solve the hang is by logging out and in again. I've had the manager take up to 10/15 minutes to 'initialise' at times.
Usually after an update i'll stop it from logging in at launch so I don't get any spinning wheel hangs, then just check it when I feel necessary. Since adopting this workflow, i've had no issues with it.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
The Application Manager is a tool that is supposed to make it easier for you to track your subscriptions and plug-ins as well as make it easier to keep up to date with the latest versions. There are people that don't care for it and choose not to run it, so it really is your choice. The downside is that when you upgrade PT, it will install it again, and you will either have to disable it, or remove it once again. |
Sorry that you're having trouble. Just did a sync here and it took 1min48sec (Mac Mini w/Sierra).
In Application Manager, click on Preferences then click Clear Cache Files. Please reply back if that doesn't help. Our KB has some troubleshooting info for Application Manager.
Avid Application Manager stuck on initializing | Intransit | Pro Tools 12 | 9 | 01-15-2017 10:45 AM |
Application Manager Stuck on Authentication | Base12 | Pro Tools 12 | 3 | 05-26-2016 10:00 PM |
Application Manager stuck on "Connecting" and/or JREloadError | Brado | Pro Tools 12 | 61 | 02-19-2016 03:27 AM |
PT HD8 - Stuck at Initializing Hardware (DSI) | RoofTopLuki | Pro Tools TDM Systems (Mac) | 5 | 07-07-2014 11:03 PM |
