Virtual Instruments - Only a few have sound...
Hello,
I've recently purchased the Avid Recording Studio bundle which comes with Pro Tools SE 8.0.3 and Fast Track. Environment: Asus A54HR-SX254V Notebook with Windows 7 Home Premium 64bit. Intel Core i3 2330M processor (2.20GHz) 4GB DDR3 RAM 500GB 5400RPM HDD Radeon HD 7470 1GB graphics Apart from all of the issues that I've had with this software (most of which are now resolved after hours and hours of searching and tweaking the OS) I now am left with one single issue which I cannot find a resolution for. When adding a VI to either an existing session, or an empty one, I am only able to hear sound coming from a select few instruments. Church Organ and one of the Synths seem to be the only ones currently that I've found. I am able to add these as the instrument, then open the MIDI editor, press any key on the virtual keyboard and sound is generated. However for 95% of the remaining instruments available to me, they produce no sound whatsoever (Pop Drum Kit for example). Either when using the MIDI keyboard, plotting notes and playing the track, and even enabling the track for recording, and then plotting the notes. I have checked the install DVD and compared the size of the VI directory on my HDD to it, and they are the same size, date etc. So there shouldn't be any installation issues at play here. EDIT: I do not have a MIDI keyboard, and only wish to plot notes on the MIDI editor available within Pro Tools. All of the MIDI options in preferences are set to none as there is no MIDI interface. I can provide more information about my environment if needed tonight (I'm writing this at work) Thanks in advance for any help and advice. Regards. |
Re: Virtual Instruments - Only a few have sound...
Bumping for great justice
I really would appreciate some help on this. |
some of the keys on the keyboard for the drum notes are dead notes and have no sound, have you gone up and down the whole length of the virtual keyboard?
I don't think that I have tested 100% of the range available. My thinking was "Surely they wouldn't have a default note range displayed, and then stick the audible ones at the bottom or top extremes just to piss you off?", maybe this is exactly what they've done!
Thanks Tim. I'll test this out tonight and hopefully get some sound out of these things. |
I've tried the full range of over 20 instruments in the list, I still can only get the church organ and a synth to do anything =(
I have the same problem. Only a hand full of VIs work. Does anyone have an idea what might be the problem?
I have this exact same problem! please tell me you've figured it out because this is frustrating!
Same here only on a Macbook.
Geez, me and pro tools are off to a rough start.
Phyllis in Montana running SE w/ 8.0.3 patch MacBook Pro w/Mountain Lion Fast Track audio interface Yamaha Modus midi keyboard |
how to just get a guitar chord strumming sound with virtual instruments? | elmo555 | Pro Tools 9 | 14 | 08-13-2012 04:55 AM |
Virtual Instruments Sound Dropping out - PT8.05 | YYR123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-18-2011 04:29 AM |
How do you use Virtual Instruments in PT9 as a sound module with an MPC? | Myestro | Pro Tools 9 | 2 | 04-30-2011 05:18 PM |
Virtual Instruments for TDM | ammusicco | Virtual Instruments | 1 | 01-25-2009 06:38 AM |
No Sound From Virtual Instruments...Help Please | Kwest For The Best | MIDI | 14 | 09-19-2006 09:30 PM |
