Old 03-20-2005, 12:52 PM
Ciaran Ciaran is offline
Default \'Fader Pack\' and ProControl Fader order issue
Ok,
I was wondering does anyone know how to set up a Fader Pack to see the 8 channels ahead of the ProControl rather than after.
ie. ch1-8 on fader pack and ch. 9-16 on pro-control.
I have read the literature, but I guess I'm been searching under the wrong heading as I've had no luck on a solution so far....
opinions welcome!
Ciaran
www.ciaranhope.com
Old 03-20-2005, 06:17 PM
filmixer filmixer is offline
Default Re: \'Fader Pack\' and ProControl Fader order issue
In the "Setups" menu select "Peripherals..." and click on "Ethernet Controllers". If "Enabled" is checked, you should see your Main Unit and Fader Pack listed. The Main Unit will be #1 and the Fader Pack will be #2. Select "none" for both, then reselect the Fader Pack in the #1 position and the Main Unit in the #2 position. That should do it.
Mark Ettel C.A.S.
Old 03-21-2005, 11:58 PM
Thanks for the pointer. I had tried it before and it had not worked. However, this time I deactivated the whole damn thing, and when I loaded them up in a different order it worked. Thanks again.
yours in music
Ciaran
www.ciaranhope.com
FS: Procontrol-Edit pack-Fader pack vudoo Buy & Sell 1 12-17-2013 01:48 PM
Procontrol with fader pack and edit pack The golfer Buy & Sell 2 11-05-2012 08:47 PM
Looking for ProControl Fader Packs and Edit Pack BassBuddha ProControl, Control|24, Command|8 6 01-31-2011 01:47 PM
Is Procontrol/edit pack/ fader pack still supported vudoo Pro Tools 9 8 11-06-2010 08:19 PM
procontrol fader pack jerico ProControl, Control|24, Command|8 0 12-17-2008 08:08 AM
