Need help Quick \" Markers move with edit \"
HOW DO YOU MOVE YOUR AUDIO DOWN THE TIMELINE, AND HAVE THE MARKERS MOVE WITH THE AUDIO?
THANKS DK |
Re: Need help Quick \" Markers move with edit \"
Which version of PT are you running? -- I believe this is an option implemented after 6.0 (not exactly sure though... anyone?)
Adrián Hernández www.clear-perceptions.com ------------------------ PT HD3 Accel Rosetta 800 + digi 192 I/O Mac Pro 3GHz X 2 Dual-Core Xeon |
7.4 CS4
I'm using 7.4 but haven't been able to conform markers along with the audio. The only way I know to do it is to import another PT session with a different start time, which could then offset your markers automatically, but quite frankly I'm way too lazy to go importing each reel that way and figure it all out. |
you can cut, copy and paste them. regular operations like nudge or alt-H don´t work.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Unfortunately, the marker track cannot be added to a group nor does the Insert Silence function work in the marker track, which is a major limitation if you're doing a re-conform. I think you used to be able to Insert Silence in the marker track, but it's "broken" these days. I hope Digi fixes it some day.
Depending on what you're trying to do, there are workarounds. If it's just a simple move, one way is to select your "All" group, select your audio to be moved, then Shift-click in the marker track to add the marker track to your selection. Now you can cut and paste down stream and keep your markers. This is why I use MIDI region groups for notes instead of markers. Then, I can also have multiple tracks of markers so I can differentiate between my notes, another editor's notes, director notes, etc.
Pascal Garneau | IMDb |
Thank you for you help, I will use the shift option you and frank discussed! Thanks guys.
How to move all markers? | fsb1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-25-2022 10:50 PM |
Move the red diamond in the tempo bar in the edit window, only some tracks move | kingheartless | macOS | 2 | 02-21-2013 03:20 PM |
how to move markers .. | john1192 | Pro Tools TDM Systems (Mac) | 6 | 01-19-2010 11:06 PM |
NEED HELP QUICK, "MARKERS MOVE WITH AUDIO DOWN TIMELINE | dkstudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-02-2008 04:27 PM |
Markers Move With Edit... | The Weed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-17-2006 02:57 AM |
