Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 12-31-2014, 01:52 AM
crizdee's Avatar
crizdee crizdee is offline
Default Maag EQ4 TDM version distortion/ crackling
Just bought the Maag EQ4 as it's a great EQ AND it's TDM. But the TDM version distorts/crackles really bad on low frequencies? Switch to native and it's ok. Both AAX native and RTAS are fine, just the TDM version which has the problem. This is not related to input level or signal path gain structure, even with a very low input it's the same. I currently have the UAD version on demo and that works fine as well.
Just to clarify... identical settings on native and TDM and it's mainly the sub frequency that causes the problem.
Anyone else seen this issue with the TDM?
I haven't had chance to really troubleshoot yet but instantiated probably 6-8 times on different tracks and always the same.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-31-2014, 08:30 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Maag EQ4 TDM version distortion/ crackling
TDM is 24bit-fixedpoint math. Use the "screw" to lower levels and you're fine. Native processing "cheats" by using 32bit-floatingpoint math. That is the difference.
Janne
Old 12-31-2014, 09:37 AM
crizdee's Avatar
No its not that. i can reduce the screw level and no difference. even with a very lower level source it still distorts/crackles.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-31-2014, 11:04 AM
tonwurm's Avatar
tonwurm tonwurm is offline
I had this issue, too (distortion, crackling in the lower frequencies). But it occured only in combination with another specific instanciated plug-in, I think it was the SPL-Vitalizer plug, but I´m not absolutely sure since it´s a longer time ago in the days of PT 8. Since PT 10 it didn´t occur again.
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 01-08-2015, 06:08 AM
Micks_Mix Micks_Mix is offline
Same problem, TDM version unusable...
Pro Tools|HDX Ultimate, 192 HD I/O, 192 HD Digital I/O, Focusrite OctoPre, Pro Tools 2021.3, Mac Pro 5.1, 24 GB RAM, Mojave
Old 01-08-2015, 06:48 AM
dtmprod dtmprod is offline
I've only used it on the mix buss & never had an issue. Having not used it on multiple trax in rest of session, can't speak to that at all. Have you spoken to Dirk about it? He's usually quite responsive to any issues that come up…..
Old 01-08-2015, 09:03 AM
JFreak's Avatar
I haven't had this issue, whether TDM/RTAS/AAX
Janne
Old 01-08-2015, 09:05 AM
JFreak's Avatar
And that said; I have Genelec 7060B sub so I'd think low freq problems would have been present here.
Janne
Old 01-08-2015, 11:21 AM
crizdee's Avatar
Not just the low frequencies! I've noticed it there all the time now if i listen carefully!
Anyway i have installed the previous version 1.4 from the legacy downloads and its all working fine now.
So its an issue with version 1.5 only
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-09-2015, 05:23 AM
Originally Posted by crizdee View Post
Chris
Thanks Chris,
I will try this, too.
The problem is indeed not only the low frequencies... In some cases the sound is completely messed, distorted and unpleasant... Sounds like Decapitator on steroids, switching to RTAS fixes it.
Michael.
mbox2 periodic crackling and distortion grafic macOS 11 02-14-2015 10:38 AM
Distortion/crackling clips SteveFireland Pro Tools M-Powered (Win) 1 04-13-2010 04:56 PM
Elastic Audio - Crackling, Popping, and Distortion lclebsch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 10-08-2009 05:24 PM
Smack! causing HORRIBLE distortion crackling problems ProToolsIgniter Pro Tools TDM Systems (Mac) 2 05-23-2007 08:40 PM
bizarre crackling distortion InjuredEar Pro Tools TDM Systems (Mac) 5 03-22-2006 07:40 PM
