Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 02-27-2012, 12:22 AM
Routingwithin Routingwithin is offline
Arrow Re: Error startin Pro Tools SE - Avid Hardware not found
Originally Posted by toki View Post
not only Pro Tools SE can't recognize the device, but Steinbergs Cubase Elements (which I installed as demo version) doesn't do as well
Yes, this indicates that it could be the device itself or the driver.. but @ this moment I think you're a bit fed up with struggling with this issue. LOL
Iam just glad you got it working in a way, and can continue with your recordings.
So enjoy it.
cheers
Old 02-27-2012, 08:21 PM
Joolaitha Joolaitha is offline
Default Re: Error startin Pro Tools SE - Avid Hardware not found
Hi toki, I've been having the exact same issue except that I have the C600. How do you go about deinstalling the device driver? I would like to try that and see if it solves my problem.
Thanks!
Old 02-28-2012, 12:10 AM
toki toki is offline
Hi Joolaitha,
in the windows start menu you can find m-audio and there the icon to deinstall the driver. The other way is to open Windows control panel, then open Add and Remove Programs, look for m-audio and choose to deinstall it.
Good luck.
Old 03-23-2012, 06:48 PM
HenryJenkins HenryJenkins is offline
Dudes, I have had this same error going down on me for a while now, seriously breaking my balls... I am about to fast track my foot to M-Audio's ass.
Old 11-18-2012, 07:31 PM
infiengham infiengham is offline
I have fixed this problem!
You neen to disconnect USB from your audio device
Uninstal you device drivers
Turn off your computer! Not restart but turn off!
Turn your computer on
Install device drivers while yyour device is still disconnected
Turn your computer off
Tunt it on and connect your device!
  #16
Old 11-20-2012, 07:57 AM
Dcader10 Dcader10 is offline
Hello toki,
I had a similar problem when I installed two DAW programs & their specific interfaces on my windows 7 32-bit laptop. I installed Pro Tools SE & mobile Pre interface 2nd. I wanted to be able to switch to each program and connect its interface. I got the same message. Support told me it was a driver conflict problem. As mentioned before you used FL which is also on your computer; Pro tools is jealous. What I had to do is uninstall my 1st program and its driver. I put it on my desktop computer. Now Pro Tools SE works on my laptop with no error message.
Hope this helps,
Dcader10
  #17
Old 04-06-2013, 02:12 AM
Ibo81 Ibo81 is offline
Hi guys,
so this seems to be "all-round" problem with C400 (maybe C600, too). I have just opened a thread in "USB interfaces" in the forum http://duc.avid.com/showthread.php?t=336883
I have got the same issue, after I disconnect the device, then only help is to reinstall the driver and it works again.
But - I hope that this wont be the only solution left for tis problem!!!
Seems like an issue of the driver
What I cant understand is that it works without problems in windows, but in DAWs not
  #18
Old 04-21-2013, 03:22 AM
Myleftoe_C400 Myleftoe_C400 is offline
I also have a similar issue and had posted about this on this forum.
I was told that my PC OS is too old and this forum is not a help forum.
You would think they would bother to read further into my previous post.
I could not find an Avid related site setup to assist with C400/C600 series hardware. It appears all things for supporting this device point to M-audio which is no longer part of Avid.
I gave up trying to get the C400 running on Windows7 and only have partial success getting it running in WinXP.
I had to resort to uninstalling the latest drivers and reverting to the old 1.0.6 version. However I ran into an odd issue, the C400 randomly fails and requests that a device driver be installed after several seconds.
Its as if the device stopped working and then gets re-detected...sound familiar?Oh and that pun was intended.
I'll try to follow your approach to removing shutdown and reinstalling and shutdown to see if this will resolve my issues. It would have been nice if Avid actually had a support page for the Fast-trak series devices.
  #19
Old 04-17-2015, 11:04 AM
totzik totzik is offline
I had the same problem. I have protools express i downloaded a driver which is a form of hardware and it worked for me. heres the link:
http://avid.force.com/pkb/articles/e...k-solo-drivers
it worked for me good luck to you -MYRA
  #20
Old 04-17-2015, 11:27 AM
find your model of protools then search for the driver download. this page may also help.
http://avid.force.com/pkb/articles/e...nload/en379411
Pro Tools SE unable to locate Avid Hardware error WIN 8? joe979xx Pro Tools SE and Essential (Win) 2 07-25-2013 11:37 AM
Found new hardware error mzimpfer Eleven Rack 3 02-12-2011 07:20 PM
Hardware Not Found error FIXED danander11 Pro Tools 9 4 11-05-2010 06:51 PM
002 Rack- hardware not found error Recengnr24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-14-2009 09:13 PM
Hardware not found error... Adman44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-04-2005 05:43 PM
