Old 05-17-2008, 08:02 PM
cprescott1972 cprescott1972 is offline
Default Feature Request: Combine two mono into one stereo track?
Hey there. Is there a quick and easy way to do this? I wasn't able to drag them in. Also, couldn't find the answer in the good ol' manual. Any of you know?
Thanks.
Mac Pro 2 x 2.66 Ghz - 3 GB Ram
OSX 10.4.11
Pro Tools 7.4
Rosetta AD as SPdif input
Digi 002R - BLA Tweakhead mod
UAD-1e card and plugs
Old 05-17-2008, 09:33 PM
barstool719 barstool719 is offline
Default Re: Combine two mono into one stereo track?
create your target stereo track
set output of 1st mono track to bus 1 (for example)
set output of 2nd mono track to bus 2
set input of created stereo track to bus 1-2
record arm stereo track > record
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
Old 05-17-2008, 11:33 PM
Hmmm... Thanks for the reply.
Well I agree that would work. I am trying to avoid re-recording the file since the sounds are already there. I just need to have them connected in the pair. Also, I am worried that re-recording the audio to get it in the right place may cause other problems. Just a step I'd like to avoid. Also, the Real Time recording can be a drag if I am doing this to like 20 different pairs etc. Any other comments or suggestions?
Thanks again.
OSX 10.4.11
Pro Tools 7.4
Old 05-17-2008, 11:43 PM
audiaudio audiaudio is offline
1. Make a new stereo track.
2. On your two mono tracks, select all the regions.
3. Drag the mono regions onto the new stereo track.
 iMac i7 2020 Monterey 16GB HD Native Thunderbolt
Old 05-19-2008, 09:09 AM
Perfect. I knew it was something simple like that. I had tried to drag things in one at a time (L and R) It didn't work. Copying over both L and R at once makes sense. Thanks!
OSX 10.4.11
Pro Tools 7.4
Old 05-19-2008, 10:30 AM
flommer flommer is offline
And keeps them aligned, too..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 07-28-2020, 02:34 PM
DHS DHS is offline
Avid. Its well past time to add this feature. When I import a large OMF I'm spending 30-45 minutes making stereo tracks and renaming. You could easily give us a feature that combines two mono and keeps the Track name intact.
Old 07-29-2020, 09:12 PM
Ray Lyon Ray Lyon is offline
Agreed
Old 07-29-2020, 11:31 PM
modified the thread title for you
Move clip to stereo track - panning is wrong - FEATURE REQUEST joren Pro Tools 2019 6 02-24-2020 07:13 AM
PT 12 - Combine two mono tracks to one stereo track WITH playlists? tooold Pro Tools 12 0 09-26-2016 06:27 AM
How to combine stereo signal on mono track? highpass Pro Tools M-Powered (Win) 5 02-26-2013 08:06 PM
Question - Can I combine two mono tracks to a stereo? tendb Tips & Tricks 1 04-04-2007 08:51 AM
Feature Request - Temp split stereo track fader... JSR Pro Tools TDM Systems (Mac) 1 05-10-2006 01:30 PM
