"Assertion..." problem while trying to rename a file
I get this warning when trying to rename a file from within Pro Tools 9: It was ok before but I get this info for a period of time. I can change a region name but when it comes to a file - I can't. I also observed a strange behaviour of PT. Each time I launch PT I get the Waves options screen which is supposed to be visible only once when you install the plugs.ticking 'don't show this again' causes no change. Additionaly, after doing something in a session PT crashes when quitting the app in a usual way (cmd+q or directly from the aproppriate menu) - this doesn't happen when just launching and quitting PT. At first I thought something strange is happening with permissions. I did a permission repair and checked the disk for errors (both the audio and system disk) with Disk Utility with no improvement. I also checked if the audio disk is set to any restrictions - it's available for all and with no excerptions (PT itself can write to the disk, the only thing is I can't rename a file from within PT) I found this topic http://duc.avid.com/showthread.php?t=327036 but nobody answered This happens on my work machine which is quite different from my private one: - MP Nehalem 2.93x4 - 4GB - 4x 1TB - 10.6.8 - mbox pro (3rd gen) - PT 9.0.6 - Waves Platinum 8 I hope this time somebody has a clue. Thanks in advance!
Mac Studio M1 Max 32/512, 2x 2TB 40Gbps + 2TB 10Gbps, 13.6.5, Logic 10.8.1, PT Ultimate 2024.3, Mackie Big Knob Studio+ |
Re: "Assertion..." problem while trying to rename a file
No option to "rename disk file" on pop-up box | 90seyes | Pro Tools 10 | 3 | 03-11-2014 09:44 AM |
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." | Elias Stiza | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2012 07:06 PM |
"Assertion" problem | rolling_beat | Pro Tools TDM Systems (Mac) | 5 | 07-13-2010 11:26 AM |
"unable to parse audio file" and "OSStatus Error -208" ! | reichman | Post - Surround - Video | 2 | 03-22-2010 04:46 AM |
HOW can you import a "stereo" WAV. file into PT as a "mono" file? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-21-2002 09:14 PM |
