Re: Was looking at finally buying HEAT..really?
Just my 2 cents on this;
1-If you have Heat, but worry about not committing Instrument tracks till mix-time, I think you are over-estimating what Heat will do to the sound. 2-If the track/mix isn't "happening", then Heat is not going to "fix" it. 3-There are lots of similar options for "that" sound. Waves NLS, J37, Slate VCC and/or VTM, etc 4-I have Heat but seem to never actually use it(old habits....). I do use Slate VTM on drums and bass, but it never makes or breaks a mix
^^^ How true this is. ^^^
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
Secondly, I like the integrated nature of Heat.. I like this way of working. I never bounce my VI's or even my external synths to audio, this is why I have an analog mixer and effects modules, as well as 4 apollo 8's.. I like to work in the midi domain unless I absolutely must commit to Audio.. This is why things like DAW VI performance are so crucial to me. I know it's weird choosing PT for midi, but I love having midi inline on the track which few DAWs do and I actually really like it's midi.. Plus, PT can add delays to the sample on each midi port to get all external gear in the tightest time possible.. Most of the others are using ticks.
Oh well, I couldn't control myself.. I really love the way it sounds...
I just figured, I will start drag and drop midi to audio as I go along and work in the audio domain on songs I want to use HEAT on. I'll keep the midi tracks deactivated and can go back to them any time.. Good enough solution and will also solve my performance issues in the meantime. Sweetwater didn't ask for the AU tax which was great, so i paid 199 instead of 220 directly. Going to play now
#16
Wow I can not believe this.. just.. wow...
the cpu usage is stupid and this project only has 12 audio tracks so far... and you can't adjust the intensity PER channel.. WTF? Global setting? wow.. I can not believe I just spent 300 AUD.. I am depressed now and need to sulk. I'll try it tomorrow on a new mix and see how it sounds. They offer bypass on individual channels but not drive? Why oh why avid.
#17
Trying it on a mix the only way to audition it. I bought it when it first came out and have used it on every mix in the years since. Its lack of per-track controls is by design. If I want to affect a particular track with more harmonic content than I hear through Heat on the mixbus I have other options. You can also raise the clip gain of a particular track to get it to drive Heat harder. It's akin to a summing amplifier in that with identical settings sparse mixes don't exhibit the same degree of coloration as dense mixes. I think of it a 2 bus on an analog console and in that respect it is more powerful than any one console or any one summing mixer. Once you understand what it's trying to do you'll see it's doing it beautifully. It's the only plugin I use that goes on literally every single mix.
Joe Egan EMP Colchester, VT |
#18
What I find interesting is that it uses more cpu the lower the core audio buffer size is.. in fact at 32 buffer just activating caused 50% spikes and stopped playback. The reason I say it's interesting is because none of these audio tracks are record armed, which means that PT should have them all on it's 1024 sample playback buffer.. yet.. when i put the buffer to 128, suddenly heat had acceptable cpu. It's sounds pretty awful when driven hard, and is not unlike other plugins of this kind really, in the way it sounds (VTM for example).. Is it doing anything at default centre settings when simply turned on? That will be a good listening test for me tomorrow.
#19
Hi all,
Every time I see a "Heat is only available on Audio Tracks" frowny face thread, I keep meaning to jump in with my partial solution. When I say partial, not on Busses or anything like that. See this thread I wrote on today: http://duc.avid.com/showthread.php?t=407631&page=2 Hope this helps someone. Cheers. Steve
2 x Systems: MacPro 5.1 (Nehalem) 2 x 2.26 Quad Core, OSX 10.9.5 (Mavericks), PT10.3.10HD, 32 Gig RAM, PCIe HD3, 192's, Sync I/O, Midi I/O. |
#20
I will check into that right this second! Cheers
WTB: Heat | dcboucher | Buy & Sell | 3 | 12-05-2018 03:37 AM |
HEAT | Mark Dann | Buy & Sell | 3 | 12-11-2014 07:42 PM |
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
Fs: HEAT for TDM/AAX DSP | mixboy bob | Buy & Sell | 0 | 11-25-2013 06:20 AM |
HELP! I am buying a Dell Laptop with intent on buying a DIGI 001 as well | xian$ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-18-2003 11:53 AM |
