Old 03-17-2019, 08:57 AM
LSD-Studio LSD-Studio is offline
Default Default Calibration 192io vs HD (0.775V / 1.228V)
Hello,
when I upgraded my 192io to the Avid HD 8x8x8, I notice that the output volume was louder than it was on the 192.
on the 192 the analog output's volume matched the digital spdif outputs volume...
I did some measuring and found out that the 192 came calibrated to
-18dBFs = 0dBu = 0.775V
While the HD came at
-18dBFs = +4dBu = 1.228V
theoretically the 1.228V should be correct for the +4dBu outputs of the Interface, so apparently the 192io came calibrated "wrong" (to 0dBu instead of +4dBu).
has anyone noticed anything similar with they blue vs gray interfaces?
I also found it odd that the "icorrect" 0dBu output seems to match the digital spdif output better than the "correct" +4dBu calibrated outputs
Old 03-17-2019, 09:55 AM
Default Re: Default Calibration 192io vs HD (0.775V / 1.228V)
Probably somebody just calibrated the 192 to -14 before it got to you - 192s were factory cal'd to -18dBFS = "0VU" = +4dBu.
Originally Posted by LSD-Studio View Post
...I also found it odd that the "icorrect" 0dBu output seems to match the digital spdif output better than the "correct" +4dBu calibrated outputs
No idea what you mean by this - SPDIF is digital so of course depends on the subsequent D/A for calibration.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 03-17-2019, 11:43 AM
JFreak's Avatar
JFreak JFreak is online now
^^ this.
Most people don't realise that 96 HD boxes were calibrated to -14 so when someone needed more track count than could afford 192 boxes, the usual trick was to calibrate 192 boxes on par with 96 boxes, because it was possible.
Janne
Need help with my 192io Ryno1127 Digidesign Hardware & Software 3 01-25-2015 02:37 PM
my output rev.d won't go lower to 1.228v melvindesk Pro Tools TDM Systems (Mac) 1 07-26-2012 08:25 AM
Need help with 192io please vgoodman1956 Pro Tools TDM Systems (Mac) 2 10-28-2011 06:04 PM
Considering HD2 and 192io but have a few questions EF Pro Tools TDM Systems (Mac) 2 03-22-2007 02:59 AM
3rd party DA for 192IO davemc Pro Tools TDM Systems (Mac) 0 06-11-2003 08:49 PM
