  #31
Old 07-14-2017, 08:58 AM
Default Re: PT Not Seeing WAVES Plugins.
Originally Posted by krsongs View Post
Yes I just did that.
Yes I did purchase directly through Waves (always do.) They have sort of a web you must navigate through to download and register; other plugin mfgrs make it so damn easy.
But two other fellows on this thread had recent Waves/PT problems just like me.
I don't remember having to register when I purchased direct from Waves; the plug(s) were already in my registered plugins page right after purchase.
Jack
QAPLA!
  #32
Old 12-03-2019, 03:57 PM
pauledwards pauledwards is offline
Not sure if this is an identical issue, but I got my v9 plugins back on line after contact Waves support. I emailed, then after a day of not hearing from them I called and got help shortly thereafter.
Below is the info I received. Not sure if I can include hyperlinks from the email here, so pls contact Waves support and/or visit the site if you need further assistance.
Good luck. This issue basically cost me 1.5 days of work, so hopefully it'll help you get up and running quickly.
Cheers,
Paul
ps. I'm on Sierra, and PT 12.8.1. With Waves v9, 10 and 11 plugs.
From Waves:
"I suggest a complete removal and re-installation of Waves
V9 can only be installed from a legacy downloaded offline installer as instructed below :
First, uninstall:
Launch Waves Central.
Go to the Settings page in the bottom left corner.
Under Maintenance, look for Uninstall and click the drop-down menu.
Check mark all the available version entries.
Once done, go to Applications and remove the Waves folder and Central application.
In Finder, click on the Go menu while holding down [Alt/Option], click on Library > Preferences and send the Waves Preferences to the trash.
In the same Library folder go to Caches and send the Waves folder to the trash.
Go to Macintosh HD > Library > Preferences and send the Waves Preferences folder to the trash.
Go to Macintosh HD > Library > Application Support and send the Waves folder to the trash.
Delete any WaveShell files you find in the following locations (if exist):
Mac HD > Library > Audio > Plugins > Components
Mac HD > Library > Audio > Plugins > VST
Mac HD > Library > Audio > Plugins > VST3
Mac HD > Library > Application Support > Digidesign > Plugins
Mac HD > Library > Application Support > Avid > Audio > Plug-Ins
Mac HD > Library > Audio > Plugins > WPAPI
Now to re-install V11:
Download and install Central.
Run Central and log in.
Go to the Install Products page in the top left corner.
Under My Products, check mark the products you wish to install.
If your licenses are not activated, you can choose a device to activate to when installation finishes under Target Device for Licenses.
If your licenses are already activated, click Install on the bottom right.
Install V10
Quit any host application.
Go to the Install Products page.
Go to the All Products tab, search for the product and check-mark it.
Make sure you've selected the V10 entry.
Click Install in the summary column.
Install V9
Download the v.9.92 Offline Installer for Mac.
Unzip the folder to your downloads folder.
Launch Waves Central and click on the Offline Installer page.
Under Install From an Offline Installer, click Browse.
When prompted, highlight the Waves- 24.5.18 folder on your desktop and click Select folder/Open.
Checkmark the products you wish to install.
Click Install.
  #33
Old 12-14-2019, 06:24 AM
simon.a.billington simon.a.billington is offline
The new Central does have a few problem solving tools in the Settings tab itself. You can clear the cache, reinstall and a couple of other things. I suggest trying that first, if you haven’t already.
Perhaps it’s even worth using Central to Uninstall, then verify that your AAX folder is clear of “shells” then reinstall again. Conflicting shells can actually mess things up for you, at this way you can rule it out.
Short of that, contact Support. They’re usually quite timely.
  #34
Old 01-05-2020, 10:29 PM
Jeremy Oswin Jeremy Oswin is offline
I had a similar issue with most V9 plugins disappearing (whether AAX, VST, or AU–I think due to installing Waves Central 11.0.50 and a V11 plugin, Berzerk.) I'm on PT 12.8.2 OSX 10.12.6. This got all AAX and VST plugins working for me again:
https://www.waves.com/support/how-to...ll-waves-v9-92
Basically it's downloading v.9.92 Legacy Offline Installer, then running it from the latest Waves Central as an offline re-installation of all V9 plugins.
HTML code is On
FS: Waves Kramer Master Tape and other Waves plugins MatthieuH Buy & Sell 0 05-16-2016 08:57 AM
Waves Plugins lahmur Pro Tools 12 1 01-28-2016 12:20 PM
FS - Waves plugins, AVID plugins Rosco1969 Buy & Sell 12 03-11-2014 11:56 AM
Waves Plugins FS $65 crandallwarren Buy & Sell 1 02-08-2014 08:40 AM
FS : Plugins alliance, avid, flux, waves plugins, blastwave sound library Roll Buy & Sell 5 03-11-2013 06:20 AM
