Old 04-03-2006, 11:01 AM
PTGuy PTGuy is offline
Default Import I/O settings problem?
Everytime I choose import I/O settings it totally screws up the routing. No matter if I choose "leave existing.... or delete...." it still creates my imported channels but leaves the existing meaning that there are identical. Therefore when I try to exit out it won't let me because there are duplicate tracks...
Old 04-03-2006, 12:19 PM
TCDet TCDet is offline
Default Re: Import I/O settings problem?
De-assign all input and output including buss's for a new set of I/O's.
Re assignment will be required.
If you keep your old (No de-assignment) then you'll need to de-select any overlaps from the new set.
If your just looking for more buss or output assignments the select "Default" in the I/O settings and all I/O not present will show up.
Old 04-03-2006, 01:24 PM
Robert U Robert U is offline
I also think that the I/O import implementation is quite messy and could be improved in many ways. Always creating duplicates is a drag. What if I wan't to use my own I/O setup on premix coming from elsewhere. Haven't been able to figure out a good way of doing that yet.
-Robert
www.extensivemusic.com
Do not import I/O settings ChrisMac macOS 10 11-12-2012 02:11 PM
Import mix settings Alex_C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-21-2008 01:33 PM
Best way to import I/O settings? Lawson Pro Tools TDM Systems (Mac) 6 04-09-2005 07:31 PM
import plugins and settings ZEUSS Pro Tools TDM Systems (Mac) 1 07-06-2003 07:45 PM
import plug in settings??? smlworld Pro Tools TDM Systems (Mac) 2 08-23-2001 01:22 AM
