Old 05-31-2018, 12:19 AM
LPstudio LPstudio is offline
Default Could not complete the Import Audio command
Hi
currently using Pro Tools 12.5.2 on Mac OS High Sierra 10.13.4. When I try to import audio I get the following error message:
Could not complete the Import Audio command because Assertion in "/Volumes/Development/183141/ProTools/NewFileLibs/Cfd/MacOS/Cfd_ImportAudioDialogMacOS.mm", line 603.
(Use the Copy button to copy this message to the clipboard.)
Is there anything I could do to fix this problem? Already tried to trash pro tools prefs without succes.
Old 05-31-2018, 05:50 AM
vh@umbodid.is vh@umbodid.is is offline
Default Re: Could not complete the Import Audio command
PT12.5.2 is not supported past os x 10.11.6 - that might very well be the base of your problem.
Besides that, I have been advised by a local Apple specialist that 10.13.4 is seriously bugged. His advice was to stay on 10.13.3 and wait for 10.13.5.
Old 05-31-2018, 07:18 AM
Pro Tools 12.5.2 is not qualified past OS X 10.11.6:
http://avid.force.com/pkb/articles/e...tibility-Chart
Besides that, a local Apple tech (and a private PT user) advised me to stay away from OS X 10.13.4 - apparently it is pretty buggy!
Old 02-25-2019, 08:29 AM
trojanrailroad trojanrailroad is offline
Did this ever get resolved? I've been having this issue for ages now and I've just been dragging and dropping audio to work around it. But now I want to import audio without sample rate converting so I need to get this finally sorted. Anyone else experience the same problem? I've tried trashing preferences and no change.
Old 02-26-2019, 05:19 AM
The only way it's going to get solved is to run a compatible combo of PT and OSX - it's that simple.
Old 11-15-2019, 06:16 AM
djani djani is offline
You can import audio if you drag and drop audio files from hard drive into pro tools time line or clip list on that MacOS system using PT 12.5.2.
Pro Tools 12.5.1 HD
Mac Pro 2.1, 8-core Intel Xeon 3.0 GHz, 16 GB RAM
OS X 10.9.5
ProFire Lightbridge
SSL XLogic Alpha-Link AX
SSL X-Desk
Could not complete the Import Audio command because Assertion ... Line 570. jmuyco macOS 2 02-23-2018 05:52 AM
Could not complete the Import Audio command because Assertion in "/Volumes/Developmen awodzanowski Pro Tools 11 2 03-22-2016 01:40 PM
Cannot complete audio import command Engine Room Pro Tools 11 1 01-19-2016 07:01 PM
Could not complete the Import Audio command because magic ID does not match ronfinch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-21-2010 03:32 PM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 10:38 AM
