  #6781
Old 08-16-2019, 06:40 PM
dg27 dg27 is offline
Default Re: i7 Builds - Specs and Results
Originally Posted by Sugarnutz View Post
Not many i9 builds yet, I just purchased the parts for a new build:
• Gigabyte Z390 Designare LGA 1151 Motherboard w/two Thunderbolt 3 ports
• Intel Core i9-9900K Desktop Processor 8 Cores/16 Threads up to 5.0 GHz
• Gigabyte Radeon RX 580 DirectX 12 GV-RX580GAMING-8GD 8Gb Video Card
• G.SKILL Ripjaws V Series 64GB (4 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600)
• EVGA 850 BQ (110-BQ-0850-V1) | 80+ BRONZE 850W Power Supply
This is very close to what I'm considering. How is it running so far?
  #6782
Old 08-21-2019, 08:11 AM
paulreed paulreed is offline
I am also interested in how your build is working out?
  #6783
Old 08-22-2019, 06:00 AM
chrisdee's Avatar
chrisdee chrisdee is offline
My new i9 rig since october 2018 is :
• Asus Prime x299-a
• i9-7940x (14 cores)
• Corsair Vengeance LPX DDR4 2400MHz 32GB
• 2 x 970 Evo, 2 x 960 Evo
• NVIDIA GeForce GTX 1060 3GB
• Win 10 Home
Works just fine with PT 2019.6 Ultimate.
Using it with Avid Omni + the HD Native PCI card
Christian D Hagen | I7 Builds | PT/OS Compability Chart
  #6784
Old 10-03-2019, 07:08 AM
rossi68 rossi68 is offline
• Asus Prime x299-a
• Win 10 Home
I was about to upgrade my computer a year ago, but I never got the time to get it done.
How are the i9 cpu doing for you?
I am looking at a upgrade kit with these parts;
1x Intel Core i9-9900K
1x ASUS ROG Strix Z390-F GAMING, Socket-1151
1x HyperX Fury DDR4 16GB 2666MHz (2x8GB)
1x Corsair Hydro Series H60 CPU Kjøler
1x Kingston A2000 500GB M.2 SSD
RME UFX Presonus digimax FS Mindprint Envoice Sony DMX r100 Lots of mics LOTS of drums
  #6785
Old 10-17-2019, 10:56 PM
chrisdee's Avatar
Hi, its working fine. I run all my sessions at 96k/32bit and use alot of different VI’s in realtime. Often 10 to 20 different VI’s in each session. I rarely freeze tracks since I need to work fast with ideas to keep a flow in creativity. Initially i hoped i would be able set and forget the buffer size to 64 samples. But even my i9-7940x (14 core) can’t handle that. So I have set and forget it to 1024 instead. That has become the «sweet» spot on my rig.
  #6786
Old 11-16-2019, 05:25 AM
benwalker benwalker is offline
Hi all,
Looking at a replacement for my 8 year old i5 2500k / 8Gb Win7 box. I'm eyeballing the QuietPC silent PCs - silence is golden and so on. I've upgraded the i5 over the years with new fans, SSDs and so on, but I'm hitting the Win7 expiration date and looking to move to something for the next 8 years.
DAW-wise, I currently run PT11 through a Lynx Aurora 16 LT-USB, summed to a Neve 8816: happily outputting at 24-48, a fistful of plugins, and only really starts crapping out when I'm loading mammoth Spitfire libraries...
For air-cooled PCs, I've seen the Nofan CR-80EH fanless cooler, which has a maximum CPU wattage of 80W. This basically rules out the Intel K/X series, but not the regular 9700 and 9900 Intels.
Thinking of
ASUS TUF Z390M-PRO
i9 9900 65W
64Gb Corsair Vengence
2 x 960 EVOs (system and personal files) / 860 EVOs (PT sessions) / SSHDs for samples
My question, really, is in true GAS fashion yes it would be great to have a 9900K burning a hole through the PC case, in the same way a 3.6L V6 is 'better' than a 2.0L 4 cylinder in the same car, but benchmarks aside what are the real world practical differences - have Avid ever said 'PT shalt not work on anything less than 150W of CPU'? Both cars go from A to B so to speak and I'm not planning to run 256 instances of Sylenth at 24-192.
If I need more channels in the future, I'd likely go Dante over Thunderbolt, since it means I can mix and match interfaces over Windows.
Any thoughts?
  #6787
Old 12-17-2019, 07:29 AM
New_Selas New_Selas is offline
How about this notebook;
Display: 15. 6" Fhd (1920*1080), IPS-Level 60Hz 45%ntsc thin Bezel 1920x1080 16:9
Graphics: NVIDIA GeForce GTX1050ti 4G GDDR5
Processor: Intel Core i7-9750h 2. 6 - 4. 5GHz
Memory: 16GB (8G*2) DDR4 2666MHz 2 Sockets; Max Memory 64GB
Storage: 512GB NVMe SS
MSI GF63 Thin 9RCX
  #6788
Old 12-17-2019, 11:41 AM
TOM@METRO's Avatar
MSI GF63 Thin 9RCX
At fist glance, this looks very good. It would be great if someone who uses this would chime in.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.12 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #6789
Old 12-27-2019, 11:20 AM
Iscrivers Iscrivers is offline
...and this?
Lenovo L340
Display 15,6" full hd
Processore intel core i7-9750h (6c / 12t, 2.6 / 4.5ghz, 12mb)
256gb ssd m.2 2242 3.0x2 pcie nvme + 1tb hdd 5400rpm 2.5"
16gb dimm ddr4-2400
Nvidia geforce gtx 1650 4gb gddr5
  #6790
Old 01-06-2020, 03:53 AM
mandal mandal is offline
It's time to rename this thread ?
i9 Builds - Specs and Results
Win10 Home (64-bit), Avid OMNI PCIe, Pro Tools Ultimate 2019.12, Avid HEAT, i7 processor, 16GB RAM, Samsung SSD 840 EVO (system disk), Siemens SSD840 PRO (session disk), Dell 43" 4K LED P4317Q
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 08:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 08:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 01:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 09:37 AM
