Old 04-01-2003, 10:03 AM
dmaxj dmaxj is offline
Default 001 and cakewalk sonar
I have some old cakewalk bundle files that I would like to run through Pro Tools and the 001. Would I have to separate each track and import into PT, in order to mix on PT???
Or, will cakewalk sonar work with the 001 and PC with XP???
Peace
Old 04-01-2003, 04:25 PM
neatguys neatguys is offline
Default Re: 001 and cakewalk sonar
Yes sonar will work with the digi hardware.
First download the digi asio driver.
Install it and when prompted select the reboot option in the installer.
Next you need to get the 2 sonar upgrades.
They are 2.1 and 2.2.
Install them starting with 2.1 then 2.2.
Next in sonar go to options and then audio then
to advanced.Under the playback and recording select asio.
Close sonar and open it again and you should be able to use the 001 in puts and outputs in sonar.
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit
Cakewalk+Sonar to Pro Tools.... roboman01 Getting Started 4 04-11-2013 06:18 AM
Sonar/Cakewalk to PT TDM 5.1.3 Alécio Costa Pro Tools TDM Systems (Mac) 0 06-17-2005 09:39 AM
Importing OMF from Cakewalk Sonar gleeb Pro Tools TDM Systems (Mac) 0 01-02-2003 12:08 PM
Sonar (cakewalk) V PT Le Percustard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-19-2002 10:40 AM
Cakewalk SONAR Rock_Artist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-19-2001 04:28 AM
