Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 04-12-2018, 06:09 AM
danyg danyg is offline
Default Dae 9173
DAE 9173 is popping up every time I scroll the magic mouse. I have a 12 core mac pro and the CPU is at 35%. No significant change with different buffer sizes. I did a PRAM reset. I'm on El Cap and PT 12.8.1 and i tried 2018 (even worse)
I think it's a OSX graphic issue because the mouse is sometimes sluggish in Logic too. Any thoughts or settings I could try?
- When I press stop / scroll / play PT plays flawlessly. When I scroll during playback I get the error.
- When I press the bank button on the controller to jump 16 tracks up and down... there's NO error.. only with the mouse
Thank you !
Mac Pro 12 core 3.46Ghz - 64 Gb ram - SSD 500 Gb - HD1 2T - HD2 2T - OS 10.10. - Mac Book Pro retina- OS 10.10. - SSL Alphalink convertor - Pro Tools 12 native - SSL Matrix console - Logic Pro X
Old 04-12-2018, 08:58 AM
Southsidemusic's Avatar
Southsidemusic Southsidemusic is online now
Default Re: Dae 9173
I bet it is El Cap thats causing this error. It is the worst OSX version ever and i would go to Sierra or High Sierra instead.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 04-13-2018, 04:11 AM
maybe this helps other people, I found the problem:
I had the Kazrog Kclip in my mix bus and it has a real time preview window that f.cks up the graphic resources even when the plugin is closed. I sent a mail to to the company.
Best
Old 04-13-2018, 04:40 PM
Kazrog's Avatar
Kazrog Kazrog is offline
Kazrog
Best
Hmm, I don't have any support tickets regarding such an issue. Appreciate you blaming my product for a situation that is literally impossible as described, though.
CEO/CTO, Kazrog LLC
Old 04-14-2018, 01:14 AM
well here we go... causing DAE error Using KClip - 1 days ago - NSX-817634
...and I even got an answer suggesting buffer size settings etc...
I LOVE Kclip and I don't blame your product but as a fact IT WAS causing the problem in my case. I wasn't able to finish a clients song for hours and after deleting the plugin I was able to add tons of plugins at buffer 256 and deliver the mix.
Best,
Dany
Old 04-15-2018, 09:47 AM
Kazrog's Avatar
Kazrog
Best,
Dany
You may be getting buffer underruns with KClip at that buffer size on that type of system, yes. Good quality sound doesn't come cheap.
However, "real time preview window that f.cks up the graphic resources even when the plugin is closed" is the impossible part. If you close the plugin window, it absolutely does not and cannot exist to do anything with the graphics resources. Of course, if your machine is running at or near peak CPU load due to a low buffer size, you can expect some sluggishness.
CEO/CTO, Kazrog LLC
Old 04-17-2018, 05:04 PM
toolz toolz is offline
1
[B][SIZE="1"]System:
PT 12.8.1 HD-Native PCIe, 48 I/O 16x16, 2012 Mac Pro 12 core 3.46Ghz 64gig RAM, UAD Quad FW, Apple 30” Cinema
9173, 9173, 9173... Hellooooo Rectifried Pro Tools 12 2 04-19-2018 01:50 AM
Tried everything what else can I do AAE-9173 A-Cee Pro Tools 12 0 01-15-2017 09:47 AM
Aae -9173 frcjt Pro Tools 12 17 03-27-2016 09:09 PM
PT 12 - When 9173 is not actually 9173? taft_mashburn Pro Tools 12 2 10-06-2015 10:28 PM
Cpu 9173 mistermackum Pro Tools 11 1 12-20-2014 03:20 AM
