Old 10-06-2015, 12:03 PM
taft_mashburn taft_mashburn is offline
Default PT 12 - When 9173 is not actually 9173?
Hello
I am pained to join the ranks of befuddlement with regards to the infamous "9173" error message during session bounces. I am aware of the the threads in the PT11 forums that address this issue.
I have:
• Moved all plugins to a temp directory out of my library, problem persists.
• Turned off all connectivity during bounce, problem persists.
•Trashed prefs and related files, restarted and attempted bounce. Problem persists.
• Migrated session data to a new session, to test for corruption of the previous session. Problem persists.
And just to help incite creative speculation, the session I am bouncing is about 30 minutes long, 16 tracks total. I've written automation on the majority of tracks. My CPU usage indicates about 5%-9% during playback.
To what twisted dictator must I swear allegiance in order for PT12 to work as it was intended by its creators?
Thanks in advance for any help!
Old 10-06-2015, 03:36 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: PT 12 - When 9173 is not actually 9173?
Not the answer your hoping for? But record to disk is your friend!! Just route your mix bus to a track and record and the file will be in your audio folder as well as your session. voila. Then if needed Export file at whatever bit rate/frequency you want. There not the answer you wanted
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 10-06-2015, 10:28 PM
Thank you!
Exactly what I did
Cpu 9173 mistermackum Pro Tools 11 1 12-20-2014 03:20 AM
AAE-9173 follow up xylie6 Pro Tools 11 3 12-10-2014 01:02 PM
PT 11 Clearly Not An AAE 9173 Error rgconrad1 Pro Tools 11 3 09-30-2014 12:56 AM
Aae-9173 txrx Pro Tools 11 5 12-28-2013 05:34 PM
