Old 02-23-2015, 12:52 PM
taylor4814 taylor4814 is offline
Default What is Current 003 Firmware Version?
PT 11.3
Win 7 Home SP1
003 console
If I put the 003 console into load firmware mode, launch Pro Tools, and there's no message, it just launches, does that tell me I have the most current firmware already?
(My firmware: [image] )
Old 02-23-2015, 08:14 PM
Default Re: What is Current 003 Firmware Version?
I would say yes. My own 003(now in the closet) ran fine all the way up to 11 and I have not had it ask for a firmware update since all the way back to PT9 Is it acting odd? I know the shuttle wheel has been broken since PT10(and is not likely to get a fix) but I never used it myself. The rest of the surface worked fine, but I moved up to HD/Native to increase my IO capability.
Old 02-27-2015, 06:36 AM
SKI SKI is offline
Originally Posted by taylor4814 View Post
PT 11.3
Win 7 Home SP1
003 console
Why are you putting it in firmware mode is probably the real question.
The software ask you to deal with firmware when necessary, forcing it into firmware mode is a troubleshooting aspect.
URBAN MUSIC-
(Hip Hop and R&B)
Old 03-02-2015, 05:46 AM
Originally Posted by albee1952 View Post
...Is it acting odd?
If the system is idle for a very long time, say several hours, occasionally 003 will seem to partially lose its connection... transport, some of the related controls frozen (though PT operations fine); a power cycle/system reboot in those instances always returns 003 to normal though, so I'm not too worried.
But sounds like the regular PT launches, as well as troubleshoot/load firmware mode without any notices/messages, are telling me that the firmware is indeed current -- thanks.
Old 03-02-2015, 05:03 PM
SKI SKI is offline
You should look into your FW drivers and system settings.
If that doesn't make a difference then look into it being a problem with your 003.
Is this a system that developed the problem or a new setup?
URBAN MUSIC-
(Hip Hop and R&B)
Old 07-20-2015, 09:41 AM
It's looking like this might be an issue with my switching the Windows default audio device setting... which I do frequently.
For general Windows use, I'll often use the 003 set as default audio device.
But Pro Tools needs for 003 to NOT be set in Windows as the default audio device, for it to run correctly.
Switching back and forth I believe, is what is causing the occasional connectivity issue described above; simply re-choosing the Windows default audio device which I set before running Pro Tools, and then re-launching Pro Tools, seems to solve the issue for me.
Old 07-20-2015, 10:07 AM
FWIW, my midi room setup uses an 003 on an identical computer as below. About 2 months ago, the surface went completely unresponsive(audio would still pass in both directions). If I swapped FW drivers, it would work for a few minutes, then go dead again. I tested on a backup computer and it worked fine. Replacing the FW card with a new one has solved this issue.
Mbox 3 Pro current Rev version petesteen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-07-2012 10:25 PM
current firmware version? Fritz ICON & C|24 0 03-08-2010 01:50 PM
current version? humpback 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2008 01:43 PM
Current Firmware? Barnaby Bristol ProControl, Control|24, Command|8 1 01-09-2002 09:23 PM
current version skylife Digidesign Hardware & Software 1 12-29-2000 01:22 AM
