Old 08-27-2010, 01:21 AM
iwalkthruwalls iwalkthruwalls is offline
Exclamation MIDI EFFECTS (Not Audio Effects)
I was wondering if ProTools supports 'Midi-Effects' (not audio effects).
See here for example: http://www.soundonsound.com/sos/oct0...sonarnotes.htm
MIDI effects process MIDI messages prior to routing the MIDI data to other VST instruments or hardware devices; for example, to transpose or create arpeggios or even... Crazy weird experimental progressions, etc...
Structure claims to support Midi-Effects, but I can't find any video or support for this.
Supports up to 128-level multitimbral playback per Structure instance and an unlimited number of parts, audio effects, and MIDI effects per patch
I do not want to buy Structure unless it supports this.
I know Midi-Effects are supported in Cubase, but do not want to switch.
Any help would be greatly appreciated.
Thanks!
Old 08-27-2010, 07:56 AM
flommer flommer is offline
Default Re: MIDI EFFECTS (Not Audio Effects)
Go HERE
Download the Structure Guide
Read about the "MIDI processors" and see if that is what you are looking for..
I don't think they are like "plug-ins" in how they are implemented, but they may act in the way you are looking for
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Audio out of After Effects scott waz Post - Surround - Video 6 02-04-2015 06:46 PM
external analog buss effects buss effects patching bryanbassett Pro Tools TDM Systems (Mac) 10 10-07-2004 04:39 PM
Applying effects to vocals: Which effects are key? GapeOne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-05-2003 10:36 AM
External Hardware effects VS plugin RTAS effects boogiewoogie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-19-2003 07:25 PM
Effects on MIDI ewash MIDI 6 05-17-2002 03:52 AM
