Old 12-08-2010, 08:02 AM
dterry dterry is offline
Default Rewire shutdown problems
Anyone successfully using rewired apps like Bidulex64 or Reaperx64 with PT9 on Win7x64, and able to shut down ProTools without it hanging or locking up Windows?
When closing the rewire app first, then ProTools, I get an error everytime and have to kill ProTools.exe in task manager.
When attempting to close ProTools first, ProTools will lockup Windows and keyboard access (e.g. no way to call up task manager and kill it). Eventually I got a BSOD and Win7 rebooted.
Any solutions to this? Rewire works fine when up and running, but I need a normal, elegant solution to closing projects to make use of it.
I may just have to go to VE Pro, though it didn't work within ProTools 8 on my WinXP system. Hopefully I'll have better luck with it under PT9/Win7.
Thanks.
Old 12-08-2010, 06:29 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Rewire shutdown problems
I have similar problems when closing after using rewire, though I never found a solution.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 12-11-2010, 08:33 AM
spenner spenner is offline
I had the same issue with Reaperx64 and PT. Switched to Reaperx32 and all is well.
Old 12-11-2010, 09:41 AM
TOM@METRO's Avatar
Right, Reaper 32-bit is the answer for ReWire.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 12-12-2010, 08:38 PM
cwsand's Avatar
Curious though I don't use many VI's all at once, but I thought the reason you want to use Reaper through rewire is to access more RAM - but isn't a 32-bit app still restricted to accessing 4 GB's? Maybe that 4 plus what PT uses is plenty for VI's - just wondering.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 12-12-2010, 10:39 PM
Correct. The 32-bit version is limited. Not sure what the limit is - you may be right that it is 4G.
I dropped the rewire idea - VEPro 64 bit server works much better.
Recording Problems-Crackling on record, Comp Shutdown, CPU usage max. NEED HELP! Kieran-Joseph Pro Tools 10 13 08-01-2013 03:42 AM
rewire problems perraultm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2012 03:52 PM
Please Help! PT7.1 to 7.4 upgrade problems/sudden shutdown moreese73 Pro Tools M-Powered (Win) 1 04-22-2008 10:36 PM
Active USB leads and shutdown problems derF Pro Tools TDM Systems (Mac) 1 10-03-2001 05:59 AM
SHUTDOWN & RESTART problems? smit1_uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-01-2001 02:53 PM
