#101
Re: New Hackintosh / PT7 monster HD PCI Rig
What is the company you ordered from? Do they have a website? Also could you give the specific model of the gigabyte mother board used for you build? Do you have a specific link for the "make it crash session from protoolsprofessional.com" you speak of? Did not find it there. Thanks
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
#102
#103
The Company is PearC.de
The Board is a Gigabyte "GA-X58A-UD3R" The graficscard is a ATI Raedon 5770 / 1024 MB (Two HDMI and one DVI Out) |
#104
Ok just finished this, 9.0.5, 003 and video all work.
Not an HD PCI Rig but a Rig none the less. Geekbench Score is 13470.
#105
Hi all,
Just wondering has anyone this running with PTHD10, PCIX HD4 and Lion? 192I/O Interfaces? I am thinking of upgrading my G5s but will definitely keep the PCI-X Cards. Cheers!
ReRecording Mixer & Venue D-Show Live Sound & Recording Engineer www.audio-machinery.com |
#106
no, 10.6.8 max
#107
hope the problem gets solved in 10.7.3
Originally Posted by JustinA "Soon" as in we should be refreshing our browsers, or "soon" as in ADC coming to LE? |
#108
hi,
just want you guys let to know that there is a great site for DAW machines out there: http://hd-recording.at/dokuwiki/doku.php?id=daw This is project is aimed to build a reference system with favored- most recommended compatible and certified components not only for a Digital Audio Workstation,… following criteria have been respected: - OS X compliant (community recommended setup for smooth osx installation) - Performance (x58 motherboard, i7 quadcore cpu,… ) - Noise (extra special silent components: case, cpu cooler, graphic card, power supply) - Cooling (special high quality cooling performance: case, cpu cooler gpu cooler) - Compatibility (compliant chipsets, eg. motherboard, pcie firewire card ) I've spent a lot of time researching the components for this system, especially to be osx compliant and certified to most audio devices (AVID/Digidesign/M-audio, RME, MOTU, Metric Halo, TC, Presonus, … ) http://hd-recording.at/dokuwiki/doku.php?id=daw good luck, nean |
#109
You're the man! Thank you... I built the machine, handed it off to the owner of the studio and, I come to find out later that he installed a bunch of cracked software on the machine. I told them to do it legit and problem solved... thank you.
#110
HACKINTOSH > USB 2.0 PORT > USB REPEATER CABLE > USB REPEATER CABLE > USB REPEATER CABLE > BELKIN POWERED 7 PORT USB HUB > MOUSE/KEYBOARD, ETC. The keyboard and mouse work but keep dropping out, and its as if they're not getting enough power... even though the usb hub is powered. Is there anything that can be done about this? When I swap the hackintosh (jetway board) for a Mac Pro G5, there's no more problem with any usb devices dropping out, even at the long distance. Is it an issue with this board? Are the g5 pro usb ports stronger or have a higher voltage or something? Sounds like it could be a problem similar to one you're having, lennieh.... let me know if you've had any luck |
Hackintosh for Pro Tools 7 - 7.4 anybody ? | zavid | Pro Tools TDM Systems (Mac) | 0 | 02-19-2014 03:51 PM |
Hackintosh Problem | pocketcalc | macOS | 2 | 07-08-2012 05:35 PM |
Hackintosh with PT9 HD Native? | PMedia | macOS | 9 | 07-11-2011 09:12 AM |
Hackintosh on my rig? | Raoul23 | Pro Tools TDM Systems (Win) | 7 | 07-01-2011 03:26 PM |
Hackintosh Help | HDK_Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-16-2010 10:45 AM |
