Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 07-03-2009, 08:04 AM
[email protected] marc.seguin@cftpa.ca is offline
Default How many drives does PT8 need?
I read somewhere that a PT8 LE system should optimally have at least three hard drives, and a fourth if you want to score video:
i) a system drive on which PT is loaded;
ii) an audio drive where all audio files live;
iii) a sample drive where all sample files live; and,
iv) a video drive where all video files live.
Does anyone know if this is this correct?
Old 07-03-2009, 09:32 AM
Craig F Craig F is offline
Default Re: How many drives does PT8 need?
for optimum performance yes it is correct
you don't do video? that's down to 3
you don't use VIs much? that now 2 drive you really need
Thank you,
Craig
Old 07-03-2009, 10:00 AM
Thanks Craig for getting back to me.
Old 07-03-2009, 10:05 AM
EGS's Avatar
EGS EGS is offline
Plus, don't forget backups. I'm using an ext 1TB USB drive for backups, and I always make DVD archives of my PT session folders. Backup backup backup.
Click for audio/video demo
Click for resume
Old 07-03-2009, 10:24 AM
Very good point.... I back-up on an external UBS drive....
Old 08-01-2009, 04:53 AM
chrisdee's Avatar
chrisdee chrisdee is offline
4 drives to run pro tools, and 4 drives to back it all up
Old 08-06-2009, 11:11 AM
iriegeorge iriegeorge is offline
I have never used more than 2 drives, system and audio. Never have had any issues with this set-up. I know plenty of guys who use more and also the old "round robin" technique, which truly dispise! I do BU all my sessions to other drives when complete, only current sessions on audio drive. i store more samples on my system and copy into whatever session I need one for. i always verify that my sessions are pointing to there correct session folder on the audio drive, for all elements of that session, takes a few extra minutes but makes it easier in the end for me. i will say one thing though, if you have more than one person using a single system it can get a bit more troublesome, not everyone takes the time to verify everything. Even when I am doing video, i keep it all together.
Old 09-05-2009, 06:13 AM
shredhed shredhed is offline
I have been using 2 drives for a year now with little problems either....I have a FW drive for my audio but am thinking of stretching to 3 for my samples. I know that FW is necessary for audio recording/playback - Would the same hold true for storing samples??
Thanks
Old 09-12-2009, 12:43 AM
M-ManLA's Avatar
M-ManLA M-ManLA is offline
I have four.
System Drive
Audio Drive A
Video Drive
Reason Drive
I will get a fifth for a second audio drive.
www.M-ManLA.com
www.facebook.com/MManLA
www.soundcloud.com/m-manla
Pro Tools 12, Sibelius First 7/Presonus Studio 192/Windows 10 Pro
Old 09-12-2009, 01:08 AM
scar97 scar97 is offline
All drives I use are internal glyph sata (I know they are expensive but I like insurance)
C: drive- system only and ONLY anything that has to do with system160GIG
D: Drive- Audio for protools 320 GIG
E: Drive- for samples 500 Gig
F: Drive- Finished Mixes 500 gig
about 10 WD passport USB drives that I keep images of everything on.
I also use DVD to back up second level of redundancy
AND just to make sure I have my own server that everything gets backed up each evening. BUT I am running 3 systems (the other 2 are for post production. That is a whole other topic)
"It aint about the stuff you got..If it sounds right you're finished..Burn it!"
For all complaints click here
DAW
Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent
Drives with PT. 7200 vs 10krpm internal drives with PT. External Fav's? LalamanPT Storage Subsystems 1 11-20-2010 02:29 PM
What drives are safe to defrag (system, project, sample drives) keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-08-2010 08:09 AM
SSD (Solid State Drives) Alleviating The Need For Two Hard Drives For PT? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 04-13-2009 12:19 AM
External USB2.0 drives as Audio recording drives injun Pro Tools TDM Systems (Mac) 2 08-26-2006 07:06 PM
ANDRE & TOM: Adaptec cards to copy from SCSI drives to Firewire drives with G4/HD? ragbor Pro Tools TDM Systems (Mac) 8 06-11-2002 08:08 AM
