Old 02-01-2006, 01:03 PM
mfleming mfleming is offline
Default Embedding CD Text and ISRC codes...
For a small project for ourselves we are going to master the songs with Protools LE. Yes, I know: it's not as anywhere as good as sending it out for mastering and I wholeheartedly agree. But, let's just accept for this project that's what we are doing.
My question is, what is required to embed CD text and ISRC codes into the files from PTLE? Do I need add-on software to do this? Is there separate software that I run after the fact that inserts it?
Thanks so much!
Old 02-01-2006, 01:11 PM
YttriumMusic YttriumMusic is offline
Default Re: Embedding CD Text and ISRC codes...
Pro Tools does not burn data to the CD. So whatever software you are using to burn the CD must support CDTEXT and ISRC codes. What software will you be using to burn the CD?
Old 02-01-2006, 01:19 PM
lemix's Avatar
lemix lemix is offline
Mark,
PT does not have the ability to author audio CDRs.
I don't know of any freeware programs that can write PQ information, CD text and ISRC codes.
All my Red Book work is done in WaveLab, which can do all that. Cd Architect will too, I guess.
The retail version of Nero is a possibilty..you should look into that.
Don't forget, the burner has to be also capable to write this info.
I don't think it will cost you a lot to send the finished masters to a mastering place, just for the PMCD creation.
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Embedding ISRC codes without burning CD? crizdee Pro Tools TDM Systems (Mac) 3 03-07-2007 04:52 PM
ISRC/UPC/MCN codes? CD Text? EGS Pro Tools TDM Systems (Win) 2 09-21-2006 12:04 AM
ISRC/UPC/MCN codes? CD Text? EGS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-18-2006 06:47 PM
ISRC code embedding where02190 Digidesign Hardware & Software 3 01-21-2002 03:47 PM
ISRC code embedding where02190 General Discussion 2 01-19-2002 07:14 AM
