Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 07-31-2020, 09:10 AM
nevillebartos nevillebartos is offline
Default Dell Latitude and Steinberg
Hi everyone
I’m looking to upgrade my extremely old dell precision, mbox2 and pro tools 7 set up. I’ve done a fair bit of research and think I’m going for this laptop:
Dell Latitude 5480 Core i7-7820HQ 7th Generation Quad Core Laptop 32GB Ram 512GB SSD Hard Drive Windows 10 nVidia Graphics
Plus a Steinberg UR-RT4 interface.
And then latest pro tools
Plus I think I need a second drive for playback.
Does that sound like everything covered. It’s a big jump and a lot of money so I want to be sure. Welcome any comments or any issues any can foresee with this set up. Things seem more complex than they used to be (for me anyway!).
Thank you.
Old 07-31-2020, 11:06 AM
Default Re: Dell Latitude and Steinberg
You may want to double-check on how well the Steinberg interface works with PT before you buy it As for the second drive, 2 things to consider:
#1-Can this laptop swap the optical drive for a second hard drive caddy?(some can, but not all). Adding a second internal SSD would be great.
#2-Given how well SSD's perform, you could also see if Dell offers an upgrade to a larger SSD(like 1 or 2 TB) which would allow decent recording to the internal(system) drive. The only caveat here relates to sample libraries(which traditionally might go on their own separate drive). If you have lots of Virtual Instruments, then maybe keep them on the C: drive(but do get a much larger internal SSD so you can fit everything) and put sessions on an external drive. Depending on available connections, that might be Thunderbolt 3(best case) or USB3(still should be good). In either of these cases, you would want an SSD in the external drive(or at least 7200 rpm). Given the prices of SSD's, spinning drives don't make much sense except for large scale backup(like the 12 TB NAS I have connected)
No matter what route you take, be diligent about backing up sessions to another separate drive at the very least. Best advice here is; if it doesn't exist in at least 3 places, its not properly backed up
Old 07-31-2020, 11:37 PM
Thank you!
PTLE 6.7 on Dell Latitude NannerPuddin' 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-19-2008 08:05 PM
Dell Latitude D620 XP SP2 rgiuffre Pro Tools M-Powered (Win) 0 12-31-2007 10:27 AM
Dell Latitude D810. almamater 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-24-2006 10:23 AM
Tried Dell Latitude? NP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-06-2006 10:05 AM
Can I use a Dell Latitude C600 protonneutron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-05-2006 08:23 AM
