trim volume pt 9 le?
i can't not find trim volume on pt 9 le any idea or its not coming with that feature ?
thank |
Re: trim volume pt 9 le?
If you mean trim automation, you need the CPTK 2 to get that (and any other 'advanced' automation) feature
www.mikeslatermusic.com PTHD9 Certified Operator 15" MBP 10.7.2 Pro Tools 10.0 Apogee Duet M-Audio BX5A's |
What is it you want/need to do? Maybe there's a simple solution
i was watching a mastering tutorial and this guy used a trim volume option where you can see waveform,volume,playlist,mute etc.. he got and option it said trim volume ... and on my pt9 i can not see it ..
Trim is part of the HD/Complete Toolkit feature set.
Incredible that you have to pay so much money to 'unlock' this feature. I think Avid should take the same approach video game developers take and allow you to unlock HD features when you do certain things. That would be fun!
Are you needing to Trim input from external devices - i.e., pre-amps, etc.
ProTools 2021.12, Lynx Aurora (n) 32 TB, Sibelius 23.2.0; OSX 10.14.6; Mac Mini: 3.2 GHz Intel Core i7; 64 GB 2667 MHz DDR4; Internal 2 TB SSD, External Sabrent TB 2 TB SSD Also ProTools 2021.12, 002R,; Mac Pro: 2 x 3.46 GHz 6-Core Intel Xeon; 128 GB 1333 MHz DDR3 ECC; Serial ATA Drives (Journaled HFS+): 2 x OWC Mercury Electra 3G 2 TB SSD; 3 x Seagate Barracudas 1.0 TB; External Firewire Drives (Journaled HFS+): 4 x Seagate Barracudas 1.5 TB and 6 x Seagate Barracudas 1.0 TB |
You can trim off line. Just open up the automation lane and select the spot and pul it up, or down as you like. But trim and VCA automation are not included in LE.
Steve
Steve Shepherd Extreme Mixing |
this guy was using the volume trim as a desser cuz is better trim the volume than used the desser ...this guys from digidesign really are all about money that's why a lot of people switch to other software's...
well thank guys for the info ... |
OK. If you can catch every ess in realtime with a fader set to trim then you are amazing.
A de-esser can respond MUCH faster than you can. Even in trim mode. Trust me. Steve
PTX 10.1.1 Volume Trim Bug? | Cryos | macOS | 6 | 03-26-2012 09:40 PM |
Trim vs Volume | Chief Pronto | Windows | 10 | 02-10-2011 07:24 AM |
volume trim in PT LE | golafs | Tips & Tricks | 9 | 10-31-2008 04:43 AM |
7.2 Volume Trim | Ken P | Post - Surround - Video | 9 | 09-21-2006 10:54 AM |
volume trim | oilbedamned | Pro Tools TDM Systems (Mac) | 17 | 04-27-2006 05:33 AM |
