Old 03-02-2002, 11:48 PM
Nine Spine Nine Spine is offline
Default Does "consolidate selection" affect quality??
I use this feature a lot when transfering sessions from my 001 to a TDM system, and I never notice any difference in the sound quality (to my ears anyway), but I was wondering how this command works. Does it simply re-write the exact code so I get an exact copy or when it uses the duplicate plugin am I degrading the audio? What about if I do it more than once with the same sets of regions?? Anybody know this?
Thanks for the help. You guys are all studs.
I.B.S. Studios
Old 03-03-2002, 01:14 AM
moosemaster moosemaster is offline
Default Re: Does "consolidate selection" affect quality??
hey don't freak me out man
Old 03-03-2002, 01:38 AM
Bastiaan Bastiaan is offline
do a test to see if its the same.
1) export the track as a file
2) consolidate
3) get that file into ptle again
4 pan both to the middle and put a eq on both
5) phase invert one channel
6) set the volume the same for the 2 channels
All you should hear now is silence. If you hera something else....there's a difference in the files there.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 03-03-2002, 10:03 AM
mattm mattm is offline
does consolidate regions effect quality? no.
~matt
Old 03-03-2002, 11:15 AM
bascani bascani is offline
How do you phase invert?
Old 03-03-2002, 11:16 AM
don't bother I just found it.
Old 03-04-2002, 03:10 AM
Ben Jenssen's Avatar
Important thing to remember when consolidating:
PT LE does some kind of "autofade" at playback, automatically. But not when consolidating, for some reason. So if you don’t make fades on all region ins and outs, you will get small clicks there.
Use the batch-fade creation.
Old 03-04-2002, 04:56 AM
Zeus Zeus is offline
Nope. There are no autofades in LE, it's TDM only.
BTW. You might want to check Pro Tools manual, where dither is explained. Apparently dither is added also when using the duplicate plug-in...
[img]images/icons/rolleyes.gif[/img]
Z
Old 03-04-2002, 08:57 AM
if use dither is selected in fade preferences then dither is used regardless of weather or not you consolidate seperate regions - that is everytime you create a fade.
Old 03-04-2002, 06:54 PM
Thanks for the replies guys, in theory my files should be exactly the same as what was there originally including all fades.
The Digi plugin manual for the Duplicate plugin says the following: "The original audio file regions are merely rewritten in place to a single duplicate file".
From the Webster's American Dictionary: "Merely, adv. 1. Being nothing more nor better than what is specified"
Apparently the exact code is rewritten, but I am interested and will try Bastiaan's suggestion when I have some time tomorrow and post the results here.
Thanks again for all of the info you have provided.
I.B.S. Studios
Consolidate vs Duplicate - "Stereo" vs. Dual Mono Behaviour rnd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-05-2013 01:03 AM
Best way to "consolidate" elastic audio tracks? rapsodie Pro Tools TDM Systems (Mac) 17 01-27-2012 10:18 AM
Anomalies introduced with "Consolidate" command (opt/shift/3) blawrie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-01-2011 11:18 AM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
Does "Consolidate" deteriorate sound? Muzik77 Tips & Tricks 5 06-14-2002 06:57 PM
