Old 03-26-2012, 04:15 AM
ha2dorff ha2dorff is offline
Default Steinberg MR816 CSX with Pro Tools
Is there any suggestions how to best hook up my two Steinberg MR816 CSX with Pro Tools?
Old 03-26-2012, 06:42 PM
nexis nexis is offline
Default Re: Steinberg MR816 CSX with Pro Tools
I use two Steinberg MR816 CSX with Pro Tools. They work GREAT! I'm not sure what you mean when you say "the best way to hook them up" Just plug your ins and outs where they belong, make sure that your firewire card is one of the recommended ones from the steinberg web site (usually any one that has a Texas Instruments chip inside it will do) If you are using Windows 7, it is also suggested to use the "legacy driver" for your firewire card. Follow the manual on how to hook up the MR816 units together. There is a nice picture diagram in the manual. That's all I can think of for now...
nexis
Old 03-29-2012, 03:14 AM
Thanks nexis :)
How are you monitoring when recording?
1. from the units (no latency)
or
2. from Pro Tools?
In theory I guess no 1 is what I want, so I can use reverb with no latency.
If so, how do you setup Pro Tools to achieve that? Just turn of the output on the channels that you record on, or is there other solutions recommended?
Old 04-30-2012, 10:42 AM
I'm able to record from unit 1, but from unit 2 I'm not.
Both units is set to "ADAT(1-6)+S/PDIF(coax)".
Any idea? Anybody??
Old 04-10-2013, 08:55 AM
johnnymacvkguitar johnnymacvkguitar is offline
If you are using the analog i/o, Connect to 2 with FW then they should up show in in the I/O sections of PT. Then choose the analog inputs you need,
I am having to use the MR Editor as the headphone monitor and use sendd from within PT to send the recorded music to the band members to hear back while they record. Its a bit convaluted and can't wait to maybe (big maybe) upgrade to an HDX systems (prolly not)
Old 09-29-2013, 10:50 AM
maylopee maylopee is offline
does anyone know where I can choose my mr816x card in Pro Tools ? It doesn't show in my list (or on my MAC System Preference for that matter) and I just reinstalled the drivers. I only see Pro tools aggregate i/o.
Thank you.
Steinberg/Yamaha MR816 csx w/ PT 9 tomdiek Pro Tools 9 6 02-12-2014 02:19 PM
Pro Tools 10 with Steinberg CI 1 bobmonsour macOS 0 12-25-2011 10:55 AM
Octopre MKII and Steinberg MR816...opinions? The Dougfather Pro Tools 9 1 06-26-2011 04:32 AM
Steinberg MR816 X and Windows7? jacub Pro Tools 9 1 05-06-2011 01:37 AM
Pro Tools HD 7.3 with Steinberg x-click Makesound Pro Tools TDM Systems (Win) 0 07-10-2009 09:23 AM
