Grid line/meter change question...
Hey guys...
When I change the meter to say, 3/4 time from the default 4/4 time, the grid lines appear to stay set as 4/4 time, which makes working in 3/4 time more difficult than it needs to be. Is this just the way it is in PT(7.3), or is there a setting to make the grid lines adhere to whatever meter one sets? thanks, Roy
rh music |
Re: Grid line/meter change question...
Sometimes you have to change the grid value before it will show properly. Like switch grid to "1 bar" and back to "1/4 note." Zoom level can make a difference in how it shows up, too.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
That didn't work, but thanks for the reply, David. I'll work around it if I have to, but I'm hoping Digi may have an answer for me. thanks, Roy
rh music |
Hi Roy
The redraw of Barlines following a Meter Change is automatic. Try deleting the DAE and Pro Tools Preferences. Start Menu > My Computer > Local Disk(C:) or correct hard drive (click "show the contents of this drive" if the files aren't displayed) > Program Files > Common Files > Digidesign > DAE > Right-click on the DAE Prefs folder and delete. Start Menu > My Computer > Local Disk(C:) > Documents and Settings > "Your user folder" > Application Data > Right-click on the Digidesign folder and delete. (If the Application Data folder is not showing: Tools Menu > Folder Options > View Tab > Select "Show Hidden Files and Folders" > Click Apply and OK.) Reboot. Regards. filosofem |
Meter Levels Don't Change | tyler23 | Pro Tools 9 | 2 | 08-07-2011 04:15 PM |
Grid bar line every 2 bars? | starburst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-07-2010 10:07 AM |
meter bar won't change | tocor123 | Pro Tools TDM Systems (Mac) | 3 | 04-07-2010 09:46 PM |
Markers the same when I change Meter??? | kfoody | Pro Tools M-Powered (Win) | 0 | 07-29-2008 11:00 PM |
Grid Line Issues | Alwaysfinlost | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-04-2006 05:05 PM |
