Old 03-14-2019, 02:28 PM
Vultage Vultage is offline
Default Pro Tools will not open without crashing!
So, I installed Harrison Mixbus the other night,... Today,. when I tried to open Pro Tools (v2018.12),. it hung up on the loading screen at "loading controllers" after a really long time,,. maybe 5-6minutes,. the loading screen finished,. I saw the PTs screen as I should,. however the waiting circle never went away,. after which, if I try to do anything else,..(load session, go to settings, ect),. PTs stops responding,. and crashes,..
I have tried restarting my interface, and PC a bunch of times with no changes,. same thing happens every time!
I have no idea where to even start with this, except for uninstalling, and reinstalling PTs again,.. :O!!!!!
I built this PC specifically for Pro Tools a couple of years ago, making sure that everything fit within their specs, as well as all components being compatible with each other. System has been working flawlessly since, until I foolishly installed another DAW! Oh,. I also have Wavelab installed for mastering,. that did never caused an issue,. which is why I didn't think anything would be an issue w HMB!!!
Windows 10 Pro
Intel i7 8700k 3.7GHz
AsRock Z370 EXTREME 4
16GB DDR4 2666 ram
Presonus FireStudio Project 10x10 24-bit 92kHz running at 48k, 128 samples
WD blue 250G SSD System Drive
WD Velociraptor 250Gb 10,000rpm audio drive
WD Black 1TB 7500rpm backup and storage
Pro Tools 2018 Native(PT since 2-2014)
Old 03-14-2019, 02:42 PM
Default Re: Pro Tools will not open without crashing!
DOH!!!! I did one change I forgot about!,. I had set my Interface buffer down to 64,.. as I was testing how Mixbus handled that,..
I've tested running the buffer down to 64samples with PTs,. and it worked,. which is why I didn't think of that,.. however,. that was with 48k sessions. The last session I was working on was 96k,. and I do believe THAT was why PTs was crashing on me! Set buffer back to 128,.. and PTs opened as it normally does!
Windows 10 Pro
16GB DDR4 2666 ram
Pro Tools 12.5 crashing every time try to open Kerochan Pro Tools 12 9 10-27-2017 03:25 PM
Pro Tools Crashing On Session Open marff3 Pro Tools 10 4 05-25-2016 12:20 PM
Pro Tools crashing every time I open a new session Ryan Butler macOS 25 10-12-2012 02:06 PM
Pro Tools 10 keeps crashing when i open Virtual Instruments ! fannar182 macOS 5 10-02-2012 05:32 PM
Pro Tools 8 crashing when I try to open a session or start a new session AbstractHabitat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-25-2012 04:58 AM
